So I was moving one of my motors between frames today and all looked good until I tested it on the stand and found that the motor won't stop! It boots up normally but then when I hit the throttle or turn the crank it activates the motor and then just keeps spinning--in fact it actually seems to pick up speed gradually.
A bit of internet sleuthing suggested it might be the PAS system at fault so I took the axle and big gear out to take a look, but there is no obvious problem: everything there looks fine. I know it must be the PAS parts though (or their connection to the controller maybe) because when I ran it minus the PAS magnet the motor behaved normally and obeyed the throttle both on and off.
So my question is: what do I need to replace? All the parts look good as new and the PAS sensor must be doing *something* because it initially responds to the crank and turns on the motor: it just doesn't know when to quit. Still, I'm thinking its probably something wrong with the sensor, not the magnet disc since its hard to see how that could fail (tell me if I'm wrong about this). I haven't opened up the controller itself yet because I was hoping not to have to take the motor off the frame, but I guess I'll have to do that tomorrow; maybe it is all just the PAS connector having worked a bit loose or something like that.
Incidentally when I was positioning the motor I'd tapped it into place with a rubber hammer and now I'm thinking that probably wasn't a good idea
I hadn't bench tested it before, though, and this motor has been out of my rotation for a while so I don't know if that was actually the cause or not. It seems to me the motor ought to be tough enough to deal with a few blunt raps, but I'll still be more gentle with it in the future.
