CYC runs 72v and has integrated torque sensing out of the box.no and also i dont think theres any mid drive that work with 72v from Factory
Many thanks, I bought it a little cheaper on AliexpressI've used a buck converter to maintain 60v from a 52v battery and that worked ok, you could try a similar thing with a step down, this looks ok and might work but it's quite big!
1500W 50A Adjustable Step Down Module Stabilized Power Supply 25-90V to 2.5-60V | eBay
It's a creative solution that should work OK for lower amperage controllers. Just keep in mind it's efficiency, I think their normally around 85-90%.Overall, this converter is a gamechanger because there will be no voltage drop and at 5% of the battery, i.e. close to 3v, there will still be full 60v voltage and full Ampere power. So now I'm glad that I decided on a 20s battery because I also made it using high-current 6p Sanyo NSX cells, so they should work for a very long time, not heat up, etc.
I just installed a current shunt to measure my new tsdz8 and it does in fact put out 1100watts. It's a great motor. Only think I don't like is the response time is a second or so. I wish it started faster when pedaling or using the throttleHello, I have an engine in the wheel now, but it doesn't work well off-road because the wheel is too heavy. My battery is 20 seconds old, maybe I could use a converter and lower the voltage.
Or maybe tsdz8 will go for 20s? it is definitely more powerful and is said to have a factory output of 1100W.
