TSDZ2 Torque Sensor Calibration
dgc
uk
I picked up a 48v TSDZ2B mid drive which was effectively new but return to stock faulty, great for me cheap spare mechanical parts, anyway had a thought, decided to open it up and check the electrics, controller dead as your hat. Anyway Aliexpress had the controller on offer so ordered one, got it, fitted it and the drive runs fine except for one problem. I seem to have to put more pressure on the pedals to get the drive to run, both pedals seem to be the same and are balanced. As a comparison on main my bikes which have the 36v TSDZ2 mid drives fitted with the VLCD5 displays, I can set the both to level 3 whereas to get a similar output / performance I need the VLCD5 display on the 48v drive set to level 5, it doe's then pull up smoothly. I would like to check the torque sensor calibration on the 48v drive and the best route to re-calibrate it. I do have a laptop with the TSDZ2 OSF software loaded on it and have used it already to update the firmware on one drive.
Many thanks all.
Many thanks all.
Tells you how to physically calibrate it but that's not usually necessary and involves disassembly.
This describes the software calibration process for casainho osf, I expect there are similar functions in the other osfs.
There's loads of info for the osfs in the specific threads, using Google to search is usually better.
beemac, many thanks for your help, at the moment I am trying to use the VLCD5 to look at the TE and TE1 values but get to the JAP EUR mode selection and the display jumps out unless I have to press something else other than the "i" button, otherwise I would like to use say the TSDZ2 Parameter Configurator or the STVP program to view the values. My problem is how to display the values without going to a KT LCD3 or an 860C.
endlessolli: Great that's the missing bit, press the two buttons simultaneous for 10 seconds under ODO menu, at least I can see what my torque sensor is doing on the 48v drive in comparison to my 36v drives and go from there.
Put this on another thread
"OK guys, with your help we have the results, which opens up more questions.
36v motor standard firmware
TE TE1
81 81 0 kgs
101 5 kgs
36v motor OSF firmware
TE TE1
156 0 0 kgs
39 5 kgs
48v motor standard firmware
TE TE1
81 81 0 kgs
100 5 kgs
On all three with a "calibrated boot" I can get a TE1 reading of around 150 so I will have to get more weights out, I think on the 36v OSF motor the TE reading of 156 is where the firmware doe's not reset on power up in the same way there is a 5 - 10 mph indicated on the display which clears almost immediately once you move the bike or when moved from TE to TE1.
So both the bikes with 36v motors are fine, the 48v results seems to suggest to me that the 48v motor is fine but is this down to the differences between the 36v and 48v motor setups. Looks like OSF is going on the 48V motor."
As from another thread
Previously but with one human 65 kgs dead weight on the pedals
TE TE1
81 81 0 kgs
101 5 kgs
150 65 kgs
TE TE1
156 0 0 kgs
39 5 kgs
95 65 kgs
TE TE1
81 81 0 kgs
100 5 kgs
153 65 kgs
Both the 36v and 48v motors with standard firmware have a very similar TE1 output which leads me back to differences between the 36v and 48v motor setups.
At least I am pretty happy the 48v motor is OK, will put the OSF on it and see where we go. Noted that the sensor span is in the 50 range on the std firmware and the 65 range with the OSF.
Ok I must be missing something because I cannot get to the te and tei values. What does under the ODO menu mean / how do you get to that?
Verify with this guide the correct button combinations to get to the hidden menu and torque values, section 5.6:
https://custombuilt-ebikes.co.uk/wp-content/uploads/2020/09/VLCD5-display-manual-for-TSDZ2.pdf
Thanks - The link does not work, but I am pretty sure I have that guide. My issue is I don't know what they mean by ODO menu/ how to get to it.. If they are simply saying select the ODO miles display then pressing Power + I for 10 seconds. it does nothing for me.
I must be missing something. the Guide states "Press Power + I buttons simultaneous for 10 seconds under ODO menu, then only press I to show “ODO”, “TRIP”, “AVG”, “TIME” , “TE” and “TE1” respectively and circularly. Under submenu “TE”, press again, it shows initial torque value, which is for service inspection use only.
How do you get to the ODO menu?
I think I know what the problem is, when you power up the drive the VLCD5 is in "ODO" and will take you to the setup menu if you press "Power & i" buttons for 10 seconds, but to get to TE and TE1 you need firstly to press " i " button once that will move you to "TRIP" , now press "Power & i" buttons for 10 seconds will will take you into a similar looking service menu where at the end you will find TE and TE1. I had this problem myself until another user helped me.
OK - That got me to it. Just for clarification for others - There really is no ODO menu. The instructions should simply say power on and then press I to advance to display trip mileage or alternatively if already powered on and the display is not showing Trip, press I until Trip is displayed. Further, at this point (at least on mine) you only need to press I +Power for like 3 seconds.
Thanks for your help!!!
I am use to industrial controllers where they are all setup with a similar set of options laid out in a circle, I see the ODO, TRIP etc as a means into "sub menus", in this case with more or less options. They are all a bit weird sometimes in the way they are written, I use to program HMI's and the layout for them is lot more logical. Yes, I have seen 3 and 10 seconds quoted. You got there , Great.
