tim565484 said:
Flashed with OSF ?....
... M400 Bafang also and it has way more power than the tsdz3.
Yes, for what I can see you have a Vlcd6 display, so you have to flash the controller only with
mbrusa's build for stock display.
See
this thread
Ofcourse it depends of the controller, that must be the same as from Tsdz2
About the power. The Tsdz2/3 has torquesensors with different sensitivity and is mostly working the best with accelerating.
The power depends of the sensitivity of it.
With OSF it is possible to calibrate the max value of it to a default expected value that works over the complete range and not only with accelerating.
