I have been trying to understand the throttle on my TSDZ8
It is almost an on-off switch with very little fine control.
I put some tape on the throttle and did some measurements.
The range of the throttle lever between min and max is 22mm
For the first 7mm of travel nothing happens.
For the next 8.2mm of travel is your throttle range
The last 6.8mm of travel does nothing.
So the throttle only operates over 1/3 the range of the lever travel
See pictures below, the 2 marks with the X in between them is where the throttle operates.
Next I measured the voltage on the throttle.
I connected a 5.23 volt supply to the throttle.
At throttle off there was 0.82v on the blue wire
At the point at where the motor is running at minimum power there is 1.8v
At the point at where the motor is running at minimum power there is 3.6v
At full throttle there was 4.48 volts.
So, the motor controller is looking for a voltage between 1.8V and 3.6V to make the motor run.
My bike has a 9 speed rear set.
I set it to 7th gear.
The bike was on a test stand during the test.
At minimum throttle the slowest it would go is 12.8mph.
At mid throttle setting it was reading 20mph
At max throttle it was reading 31mph
For the throttle to be more usable either the motor controller needs reprogramming to start providing power when the throttle is outputting say 1 volt and give max power at say 4.2 volts
Or, we try to find a throttle that outputs say 1.5v at minimum and 4.6v at full throttle.
This would make the throttle actually usable!
