I am trying to solve the age-old problem of torque vs. speed. I have a large go kart that I have a jack shaft on. My thought was to connect one motor with built-in gear reduction to the shaft with a freewheel sprocket on the shaft and a second, faster motor to the shaft as well. When I start moving, the faster motor will be working way harder than it wants to, but the gear reduction motor will get things moving quickly. Then as it gets to the max speed of the gear reduction motor the faster motor will be doing all of the work and the gear reduction motor will be essentially spinning with no load. The freewheel sprocket would keep the faster motor from turning the gear reduction motor at insane speeds.
Does this seem like it would work?
