Charging a Promovec 50776-BL-C-36V (36V 17.4Ah) battery with a Kunshan ST Electronics SHC-8100LC charger. The charger becomes dangerously hot and will never switch from red (charging) to green (charged) LED. The battery does get hot. It performs fully ok for a couple of years average use.
The battery (not connected) shows 38.8 VDC fully charged. The charger (not connected) shows 42 VDC. Someone mentioned in another forum post that my battery voltage is way too low. I haven't verified this (yet).
ChatGPT suggests a few components inside the charger that could cause this symptom, i.e. faulty shunt resistor, TL431 op-amp, opto-coupler, etc. It could also indicate a problem with battery cells or NTC-thermistor inside the battery.
I guess I'll have to examine the components inside the charger.
