mrcashback
- Joined
- Apr 20, 2016
- Messages
- 28
Im a good 10yrs into a build, thats mainly the result of me giving up every couple years thinking "ill see if i can get that controller working this time. So, now i want to ditch it and get something that actually wont give me any grief.
Must haves:
5000w Minimum capacity current motor is 5kw, but that could change in future
90A minimum, so i can run current motor at redline at 56v if i wanted to.
Voltage range 56-92v (wider range would be even better) current battery is 46v, but i would like to increase that
Features:
Bluetooth or wifi control on phone
Ability to have at least 2x preprogrammed settings that can be switched wirelessly between roadlegal and offroad, and optional input for key
Regen breaking
Would be nice: but not essential
5v/9v/12v outputs for usb/phone charging or other devices
Realtime phone monitoring of stats, speed,watts,volts,amps
Built in BMS and ballancer
Ability to recharge from other various DC sources of varied voltage
As compact as possible footprint to fit inside frame (if i can)
Water resistance
What options exist that others are happily using? Ive bought a number of aliexpress BMS's and ballancers for domestic battery usage and solar, and one of them failed and blew up a $30,000 battery pack letting it overcharge, the and the others all have various quirks that make them useful but anoying, like one drops bluetooth control when the pack is out of range so theres no easy way to easily turn it back on and reprogramm it when its in that state. Some dont have wiring guages heavy enough to support the amperages they claim etc etc, so, if you have one thats great "but" has quirks, please note the quirks!
Thanks so much!
Must haves:
Features:
Regen breaking
Water resistance
Thanks so much!
