chucho
Thank you very much for the work and sharing
Awesome! Thanks heaps, was just what I was after.izeman said:here you go: https://dl.dropboxusercontent.com/u/1174616/xpd-0.3.2.zip
should include everything. pm me if it's missing something
The difference between EB2XX and EB3XX is very much like looking at a Tangerine verses a Mandarin: They both appear to be like small thin-skinned oranges, yet beneath the surface there are subtle changes that are easily recognized if you had both in hand to compare.PeeHell said:Does any of you know what is the change in programming between EB2xx and EB3xx ? I mean why won't it work to program an EB3xx with the EB2xx controller type selected. Is it only software or it's more complex than that ? When Anpaza added "support for EBxx controller", did he do it simply by adding a few line in python ?
The BerliOS open-source hosting deceased.jorijnsmit said:Love the XPD project, it is a shame I cannot find it at its usual spot anymore (http://xpd.berlios.de/ seems to be dead). Luckily the files did end up on Sourceforge somehow, at least that's where I was able to find them: http://sourceforge.net/projects/xpd.berlios/files/?source=navbar.
DAND214 said:If you bought it from EM3ev/Cell_man, you can get the software from him.
You will need the programming cable. you also need to know which board you have.
Why do you want to reprogram it? Once you flash it you can't go back, unless you have the qriginal profile from Paul/Cell_man.
Dan
DAND214 said:Yes you can reset it if you have the files.
Look at the asv.
the three speed switch is a nice option. It can tame the throttle down if needed.
What voltage and motor are you running?
Dan
