Wooden bicycles, lots of pics
Re: Wooden bicycles, some pics
Postby spinningmagnets » Tue Jun 09, 2009 3:01 pm
The "TJ Flyer" (Truss Joint) 3/8" Baltic Birch plywood over Laminated Veneer Lumber (LVL)
spinningmagnets
Postby Zoot Katz » Wed Jun 10, 2009 12:14 am
I forgot this one Justin found on the prairies.
Richard Pitre's bike made of hockey sticks:
Zoot Katz
Postby spinningmagnets » Tue Jun 16, 2009 7:13 pm
I found the Igor Ravbar bikes fascinating, made of steam-bent strips. I recently stumbled across a story about furniture making where strip wood was bent by applying the side of the strip to a hot-pipe (heated by an electric element or a small propane torch).
The heat partially melts the connective lignin "glue" between the fibers, and if clamped in shape while cooling, the strip will retain its bent shape. Gluing several similarly bent strips together makes a laminate that is light and strong with a certain amount of springiness to it, much like a laminated archery bow.
this site is for making guitars, but it had the best pics for the hot-pipe wood-bending method.
http://gicl.cs.drexel.edu/people/sevy/luthierie/guitarmaking_guide/side_bending/side_bending.html
spinningmagnets
Postby Lock » Tue Jun 16, 2009 9:17 pm
Wood is a fantastic building material. It is only important that 1)you dry the moisture content down to about 10% in the finished structure and 2)that you absolutely seal the wood completely to keep any moisture out after that.
tks
LoCk
If you like this message feel free to donate BeerCoins (BTC) to:
1LxAXWmbjY6SeMf8r9HHhSKt6pWyPvWg6L
Toronto Electric Riders Association:
http://www.ebikeriders.com/
Canada, eh?
Lock
Postby spinningmagnets » Sun Oct 04, 2009 11:25 pm
This is "Le Zelo", a homebuilt wooden recumbent tadpole trike from Boris Beaulant.
http://www.borisbeaulant.com/
From Sakari Messuilla
spinningmagnets
Re: Wooden bicycles, lots of pics
Postby spinningmagnets » Sun Oct 04, 2009 11:46 pm
From the "Atomic Zombie" website, Jon in Maryland
spinningmagnets
Postby Lock » Mon Oct 05, 2009 7:05 am
Beautiful things! Saw this concept the other day, here:
http://www.sandwichbikes.com/
...but it pales in comparison (although intended as super-cheap/easy to build...)
tks
Loc
Canada, eh?
Lock
Wooden fenders?
Postby spinningmagnets » Mon Oct 05, 2009 7:53 am
Here's a great link about making your own fenders out of thin wood. It looks like a great winter project when you're stuck indoors. You can make them very simple and classic, or as complex as you want if you have an artistic streak.
Once the thin wood substrate is shaped, you can take a razor blade and cut veneers into patterns of stripes, diamonds, or any shape you want to make a attractive skin to add. Add a coat a clear sealer and you're set. Home-made guitar websites have some great info with lots of pics on making a skin of attractive wood designs.
http://www.momentumplanet.com/components/how-make-your-own-wooden-bike-fenders
http://www.woodysfenders.com/store/
spinningmagnets
Postby def215 » Thu Oct 08, 2009 12:51 am
thats just amazing. i wouldnt think that bike could be made out of wood but that proved me wrong. there are some pretty cool designs that they have. how about building your own http://www.instructables.com/id/How-to- ... o-Bicycle/
Project: E-BMX - Completed, debugging.
Konion Powered!
viewtopic.php?t=14550
Project Min-E Ped:
viewtopic.php?f=35&t=25636
def215
Postby spinningmagnets » Thu Oct 08, 2009 6:49 am
Good find, def215, I have seen pics of bamboo bikes on the web, but the instructable you found had great info on the process, so a home-builder could make one themselves. I originally started the wooden bikes thread because I was interested in collecting info and examples of methods for construction used in the past, and I knew wood could be very strong and reasonably light if engineered properly. This would allow me to make a custom frame just the way I want (and I have odd taste). Pic is from bamboo-bike link above (frame ended up being VERY strong)
spinningmagnets
Postby torqueon » Thu Oct 08, 2009 7:00 pm
great workman ship
torqueon
Postby spinningmagnets » Wed Oct 14, 2009 8:37 pm
A Long-Wheel-Base (LWB) recumbent. Lots of good building advice, also take note it has a rear suspension. It would not be difficult to redesign this with a break-apart joint in the center for storage or transportation...
http://www.time-compression.com/x/guideArchiveArticle.html?id=11046
spinningmagnets
"Bugatti" design
Postby Lock » Fri Oct 16, 2009 7:26 pm
Canada, eh?
Lock
Postby spinningmagnets » Tue Nov 03, 2009 7:59 pm
Random art bike, no info...
spinningmagnets
Postby Mike1 » Thu Nov 05, 2009 4:47 am
I once had a bike with a wooden frame, wooden wheels, wooden gears, wooden seat, wooden batteries, wooden controller, and wooden motor.
It wooden go :D
Mike1
Postby def215 » Thu Nov 05, 2009 11:16 pm
Mike1 wrote:I once had a bike with a wooden frame, wooden wheels, wooden gears, wooden seat, wooden batteries, wooden controller, and wooden motor.
It wooden go :D
hahaha...good one. i guess something like that wood be hard to build...lol
Konion Powered!
Project Min-E Ped:
def215
Postby gestalt » Fri Nov 06, 2009 12:57 pm
this thread is reminding me of that futurama episode where bender goes "low tech". I have been tossing the idea back and forth of a bamboo ebike based on the utility designs that those calfe guys are teaching people to build in africa
http://www.youtube.com/watch?v=2RdxKXz216w
- be seeing you
gestalt
Postby Jonathan in Hiram » Sat Nov 07, 2009 4:29 am
Here are a few more I've found..
plywood bike 1.jpg (120.88 KiB) Viewed 6405 times
plywood bike 2.jpg (114.27 KiB) Viewed 6404 times
plywood bike 3.jpg (116.65 KiB) Viewed 6387 times
plywood bike 5.jpg (44.53 KiB) Viewed 6384 times
plywood bike 4.jpg (87.27 KiB) Viewed 6401 times
plywood bike 6.jpg (89.29 KiB) Viewed 6401 times
plywood bike 7.jpg (121.52 KiB) Viewed 6400 times
"Any sufficiently developed magic is indistinguishable from technology" -Agatha Heterodyne
"Sometimes I get tired just smilin' " -The Checkered Demon
My recumbent "Grocery Getter" viewtopic.php?f=6&t=57678
Jonathan in Hiram
Postby Lock » Mon Nov 09, 2009 7:16 pm
Just seems appropriate to add this video here (wooden motor!)
tks
LoKc
Canada, eh?
Lock
Postby Zoot Katz » Tue Nov 10, 2009 1:14 am
Lock wrote:Just seems appropriate to add this video here (wooden motor!)
Revelstoke and other places of the BC hinterland had their own hydro powered generating stations for the nearby town.
The one in Revelstoke had huge wooden gears.
Mills, monasteries and militaries ran on wooden gears and shafts for much of their early history.
A recent show at the Vancouver Museum exhibited a third-world ambulance made of bamboo.
I've seen a few different bamboo trailers, lashed together with inner tubes, roaming Vancouver's streets.
Bamboo is relatively expensive compared to lashed together ladders, lawn chairs, kids bikes and baby trailers from the trash.
Use the materials at hand.
Zoot Katz
Postby Jonathan in Hiram » Tue Nov 10, 2009 4:31 am
Zoot Katz wrote:Revelstoke and other places of the BC hinterland had their own hydro powered generating stations for the nearby town.
John Harrison was the man who invented the first marine chronometer, capable of accuracy sufficient to determine longitude. Harrison was originally a carpenter and joiner and created many clocks from wood, one of which, crafted in the early 1720's was at Brocklesby Park, North Lincolnshire. This clock operates to this day, and like his previous clocks has a wooden movement, oak and lignum vitae.
http://en.wikipedia.org/wiki/John_Harrison
Jonathan in Hiram
Postby spinningmagnets » Tue Nov 24, 2009 7:37 am
Anonymous builder, looks like a construction woorker...
spinningmagnets
Postby spinningmagnets » Thu Jan 14, 2010 9:01 pm
spinningmagnets
Postby def215 » Thu Jan 14, 2010 9:24 pm
that is a really good looking wood frame. nice find spinningmagnets
i found this one strange, but i like it for some reason
oddly shaped if i may say...lol
p.s. looks like a motor could be sneaked into that frame somewhere and hidden into the wedge-shaped frame. i kinda wanna build that thing now...lol
Konion Powered!
Project Min-E Ped:
def215
Postby 12p3phPMDC » Wed Jan 27, 2010 9:06 pm
Great thread SpinningMagnets!!!
I'm amazed at the ingenuity displayed in this thread... it's awesome :mrgreen:
The old chinese carpenter crank bike seems to be the most resourceful of all the builds....
my hats off to all them. :lol:
"If you don't follow your dreams, you might as well be a vegetable." Burt Munro
The reasonable man adapts himself to the world;
the unreasonable one persists in trying to adapt the world to himself.
Therefore all progress depends on the unreasonable man.
-- George Bernard Shaw
12p3phPMDC
Next
Return to General Discussion
Who is online
Users browsing this forum: Ade, friendly1uk and 3 guests
