I've been thinking of converting a honda crf50 or similar small bike to electric and wondering if anyone has done anything similar?
I've also taken notice to the qsmotor 138 3000w and the smaller 120 2000w, I see the 2000w version is sold with a 72v 150a controller, does this mean the motor has a peak output of approx 7kw?
I think the 3000w would be overkill as I had read someone was running it at 15kw or more :lol: These motors also come with a 17mm shaft (I think) which fits a standard 420/428 sprocket which a crf50 already uses which is handy..
Does anyone know the kv of the 2000w version? I think I also read somewhere the 3000w version is 73kv
If the 2000w motor is also roughly 73kv and I ran the motor at 48v for 3500 rpm, then with a 13t front sprocket and 36t rear and a 10" wheel does the equate to around 35-40mph? Is that reasonable for this motor? Never been great at gear ratios!
Or would it be better to run 18s 75v with 13t front and 41 rear for around 50mph??
iif anyone has any ideas or info please share, cheers!
