Kingfish
Before I tinkering off the deep end I would like a bit of help please:
Last year I bought a High Power Li-Ion Battery Charger, Model: HP8204L3.
It’s been a nice little unit and seems pretty solid. I recently switched from LiFePO4 36V battery system to a 10S 37V LiPo system and this charger still performs admirably. However I must note that I find it caps off the charge a little on the high side at 43.6V, and I would like to trim that down a tiny bit to a safe 42.5-43V range.
Here is a picture of the inside; as you can see there are 3 trim POTs on the left. The small white 2-Pin Molex connector immediately right of the POTs is for the fan, and the larger 2-Pin Molex to the far right below the aluminum heat sink plate is DC Out +/-
I need just a bit of hand-holding here:
Could one of you fine folks explain which POT adjusts what aspect, identify the test points, and how best I can twiddle this critter down please?
Sidebar; I actually have another request as well:
Sadly I recently bought three Meanwell SP-320-48 PSUs but it’s looking like these are more trouble than they’re worth to modify.
I am open to alternatives. Would it be possible to take the 48V/16S 3A LiFePO4 Smart Charger version and ramp it up to 63V for a 15S LiPo configuration?
Thanks very kindly, KF
