Gypsy
- Joined
- Jan 18, 2014
- Messages
- 33
Hello, I have some questions regarding building and charging a Li-poly pack. I know this info is on here somewhere but I am having trouble with a few things.
I found a really good deal on some packs with these specs:
Minimum Capacity: 5000mAh
Configuration: 4S1P / 14.8v / 4Cell
Constant Discharge: 20C
Peak Discharge (20sec): 30C
Max Charge Rate: 5c
Pack Weight: 528g
Pack Size: 139 x 45 x 44mm
Charge Plug: JST-XH
Discharge plug: 4mm Bullet-connector
My questions are:
Can I run a 36V controller/motor system with these in a 3S2P setup? It would be a 44.4V 10aH pack.
Is there a charger that will charge the whole system at once. If so what if I made it 15aH?
I would like to use a BMS from http://www.bestekpower.com/148v4spcmbmspcbforli-ionli-polymerbatterypack/. Which one is best for this application and how many do I need?
Would this be a decent battery for light commuting on a cruiser bike?
I will be replacing the controller as well, any suggestions on that?
Any advice would be appreciated!
Thanks,
Gypsy
Max Charge Rate: 5c
Pack Weight: 528g
Charge Plug: JST-XH
My questions are:
Thanks,
Gypsy
