wesnewell
The easy way is to just use 4 of the bottom 2 packs balance leads. If your bms only has 12 balance wire places, Just use the bottom 4 of each pack. It really depends on how the BMS is designed. It could be designed to work as a 12s bms with only 11 balance wire connections and still function as a 12s bms. In this case it would use the end cells main positive and negative connections as the 2 other balance wires needed.
