When comparing cells or batteries their internal resistance is a parameter. But if the cells/batteries have different capacity or different voltage the number isn't directly comparable. It would be better to use a number which is directly comparable.
My proposal is to make this number by multiplying the cells/batterys internal resistance with it's capacity and divide with it's nominal voltage . That number would be directly comparable between cells/batteries with different capacity and voltage. The lower the number the better.
Example 1:
Type: A123 M1 LiFePO4
Nominal voltage: 3.2V
Capacity: 2.3Ah
Internal resistance: about 10 milli ohm
Internal resistance comparison number: 10 milli ohm * 2.3 Ah / 3.2 V = 7 milli hours
(Yes, the unit will be hours)
Example 2:
Type: Sanyo RC-3600HV NiMH
Nominal voltage: 1.2V
Capacity: 3.6Ah
Internal resistance: about 4 milli ohm
Internal resistance comparison number: 4 milli ohm * 3.6 Ah / 1.2 V = 12 milli hours
So, even though the internal resistance is lower than A123 the comparison number is higher. That is because you will have to put these in series (which increases IR) to make the voltage of a A123-cell, and you will have to parallell "one and and a half" A123 to make the same capacity. (which lowers IR).
Example 3:
Type: Zippy Flightmax 5ah 20C cell LiPo
Nominal voltage: 3.7V
Capacity: 5Ah
Internal resistance: about 5 milli ohm
Internal resistance comparison number: 5 milli ohm * 5 Ah / 3.7 V = 7 milli hours
So, a Zippy pack will have about the same IR as A123 M1:s configured to the same capacity and nominal voltage.
What do you think about the idea?
The number could be called "corrected IR" or similar.
Example 1:
Capacity: 2.3Ah
Example 2:
Capacity: 3.6Ah
Example 3:
Capacity: 5Ah
