Gausi
100 µW
Hello
i read much about the shenzhen ecrazyman controller ... nearly looks my scooter controller:
i want little more speed .... and i try to change the resonator original 20Mhz to 24Mhz .... but the speed is the same.
Pin 4 from the MCU is the throttle input. The Motor starts by 1,26V the max. speed is by 2,91V
When i give more "speed" the throttle stops at 4,3V . There is no different between 2,91V and 4,3V.
On this sitehttp://wwwhomes.uni-bielefeld.de/rgausmann/Controller/ are more pics about the controller
Only more voltage ( nominal 48V ) gives more speed ... my oscilloscope shows the difference between 48V and 56V
Pin 21 & Pin 5 are from current limiter OPAMP LM358
In normal Modus ( ECO-Modus ) max. 35A will run to the Motor .... when i press the power button the current is max. 64A for 35sec. After this time the current fall down to eco current.
Know someone here something about contoller with the same circuit with the PIC16F72? Mayby an idea for more speed?
mfg
Gausi
mfg
Gausi
