Hi all
I had 2 out of the 3 hall sensor failed and now I am wondering if I should replace the hall sensors or buy a sensorless controller. I'd rather buy a sensorless controller really rather than opening and replacing the hall sensors but I've read most sensorless controllers don't start the bafang smoothly .. there is a clutch( hammer ) noise. Is there a controller that won't do this ( but not being soft start ) ? Which one would you recommend ? Is clutching(hammer) noise only when you start the motor from dead start ? Because some people report this noise not only when they start.. Is it something to worry about ? Where could I buy the hall sensors if I would like to replace them ?
Thanks !
Thanks !
