NeilP
1 GW
I have a 72 v 48 amp Xlyte controller, working fine with 3 way switch
I have 3 extra plugs. B, C, D But they do not match what I have on brakes, pedelec or cruise
The cruise plug on the controller is B above...4 pin on 5 pin connector
Cruise switch
Cruise switch wires
How does the cruise system work? any one got any ideas?
Could probably guess the pedelc system but would like to be assured that I am correct before I do it
Pedal assist is like this
Pins are not in a plug. three of them, yellow, black and red from sensor
Three pins on the controller plug C
Guessing, ground, 5volt and return...Is the pedal sensor a hall effect system? sending out pulses...on the yellow line?
The brake levers are 2 wire on/off switches, but brake connector is 3 wire. I have hydraulic disks now, so will need to make something up, but what are the three wires from brake connector? How is that wired...can e-btakes have a hall system as well? Ground, 5 volt and signal?
Cruise switch
Cruise switch wires
