avandalen
Here is a method to build a switch into a brake lever; the brake lever doesn't have to be replaced and no external switch is needed. I use Hall effect sensors as switch, because they are reliable, watertight, small, and inexpensive. Used is the SS411P, but almost every hall sensor may be used. The 5mm magnet comes from a PAS sensor magnet ring. As an example, the Shimano Deore XT brake lever is taken:
See more here:
http://www.avdweb.nl/solar-bike/mechanical-issues/brake-switch.html
See more here:
