Reid Welch
Force cooling of this motor was first accomplished
with the technical help of fechter some months ago.
I'll repost pictures of the motor modifcations later on in this thread.
the first lash-up
Illustrates the original blower plan
It worked well enough to run the motor hard on 36V without overheating.
Yet, it was sub-optimal in terms of air flow--the small hose diameter, the run...
...and where to put that bulky blower?
I doublestick-taped it on the seatpost rack.
The airflow was modest, but enough.
I wished for more airflow.
Then the seatpost rack broke off (SLA load did that) and I've been on 24V since then.
Now that I'm going back up to 36V with a new lipoly pack
I need to lash on a blower again to air-through cool the armature
of the brushed, 250W output Unite MY1018 gear motor--commonly found on cheap new Currie bikes.
If these 24V motors are run too very hard they can and do burn out;
they're only rated for 250W of power output. The windings go black.
If overvolted and run at extremes (bike speeds in the low 'twenties)
the waste heat generated by this undersized motor is considerable.
No amount of external heat sinking can carry off that several hundred watts of wasted power from the armature and its commutator.
Therefore we must air-through cool,
the same as other small motors run at high power levels.
An additional benefit: brush dust won't befoul the motor.
Commutation will be optimized by the presence of ample water vapor in the cooling air.
Humid air is also a more efficient heat-soaker than dry air.
This motor will run cool even with 1,000 watts power input.
It will become rate-able as if it were a 750W/1HP motor--
albeit at the cheat of considerable wasted battery current.
It's that wasted power that must be carried off continuously
at power levels much greater than design center.
Also,
the cooler the windings the more efficiency retained.
_____________________
Ideals: short air path, few bends, large diameter airway, ample airflow.
Although the fan assembly of this old hair drier will protrude from the side of the motor
and possibly get kicked off in time
it will be easy to pop back in place.
Designing as it goes along with progress reports via pictures:
the first lash-up
Also,
