hejo said:
Regen with the Crystalyte controller?
I am confused.
Why did you start your experiment at a status of more than 40V?
If you had 35V and keep your Regen current at around 6A you should never reach dangerous voltage levels.
I am using a Kelly controller (not yet utilising regen because of freewheel) but plan to installa second motor into frontwheel for breaking / regen.
It would be great if some of the experts here could open a thread explaining about the basic physics of regeneration / recuperation, about realistic efficiencies etc.
Example :
Going uphill at 250W (320W drawn from battery) approx 80% efficiency for 20 minutes consumes 107Wh
Going downhill at similar speed / current : what would be the amount of energy charged back into the battery / the resulting efficiency?
Perhaps he was using another controller, or a regen add-on ?
I'm no expert on regen; "Real Experts" don't have time for these forums. But, I know electronics and the basic of newtonian physics.
There are IMO just too many variables to give a single figure or set of figures for regen efficiency. In the tests the OP did, the situation was virtually ideal, with a big hill down for much of the ride. I guess you could say that with nothing but a big hill down you get infinite efficiency: power out / power in = some number over 0.
I'd say the absolute maximum efficiency you could get on a trip ending at same elevation as it started is 49% if the motor runs at 70% efficiency for both uphill and downhill (0.7 x 0.7= 0.49).
This assumes absolutely no rolling resistance or wind resistance so is not achievable in real life.
I'd guess the absolute maximum added range (not efficiency) you could get overall would be 10%. Values of 1% to 5% would probably be more realistic under most conditions, considering the inefficiency of DC-DC coverters to up voltage for charging, charging losses etc.
My Prius is reputed to gain about 1 or 2% in mileage with regen, depending on many factors of course.
I'd say the biggest thing you could do to increase regen recapture on downhill is to keep your speed under aero thresholds of say 12-20 MPH. (With regen and not friction brakes of course.) Too much energy is lost to the wind otherwise.
In the end, I don't think regen is worth the trouble unless you have a lot of hills. Ebraking is IMO potentially wonderful though, and usually comes with regen.
