Hey all,
I was wondering if any of you have experience running Ebike style controllers on RC outrunner motors like a Tacon Bigfoot 160 245KV. The 2kw motor controller from sunwin that I have bought seems to be heating my motor up significantly. I am running the motor with external hall sensors and I have a heatsink mounted to the stator. The controller seems to pull above 2kw from the battery when looking at my Wattmeter. I was running a VESC on the bike at around the same power level and it didnt seem to heat the motor up as much as the ebike controller is. I also noticed that the VESC will ramp up the wattage based on load or something while the ebike controller seems to want shove 2kw into the motor even with no load on it.
Is the heat problem I am having because of an improper application of the ebike controller on an RC motor due to the different characteristics of the RC motor or is it something else?
Thanks!
Thanks!
