Here's the current (EDIT: (sic) current, pffft, it still keeps changing, I'll add the changes as new posts on this thread rather than edit this one) incarnation of my GNG 450 kit.
Just finished putting it together. I'll come up with something a bit neater to cover up the controller etc and put in a master switch as unplugging the deans plug isn't going to work long term.
I haven't tested it much in anger in the current form, but I saw 2480w on the CA yesterday during a test run. The BMS didn't complain so I won't
GNG 450 kit
2003 (I think) Kona Stinky (26x2.5 tyres) with Marzocchi bomber forks (standard)
15AH LifePO4 (ping? from China) with BMS
Cyclone isis chainring set running 48/34
04b chain primary (will be changed to 25 when I've gone through the current batch of chain) 11/57 primary reduction
9 FET 3077 Mark II (Sensored) LYEN Edition Controller
Modified Lightningrods V1.0 top sheets
Modified original GNG bottom sheets
Modified front derailer with extra chain wheel
Modified bottom chain guide - from an old reflector
Modified left hand thumb throttle (is taking a little getting used to but makes the right side controls less crowded)
GNG 450 kit
