hie2kolob
Here are a few pictures of two Cannondale’s that have been converted with the BBS02 48V 750W (25A) kit. Both kits were purchased from Paul at EM3ev.com: http://em3ev.com/store/
I would highly recommend Paul for your BBSxx conversion; he is easy to work with and stands behind what he sells. Yes, you may pay a little extra over other Chinese merchants but he is honest and reliable!
This old black Cannondale F5 was converted to be used along the Rocky Mountains that are only a mile or so away. As I get older it has become hard if not impossible to keep up with my sons that are competitive road and mountain cyclists. Even though I typically ride my Cannondale EVO 100–150 miles a week - training does not compensate for age.
PAS on the Bafang BBS02 is simply amazing! Here is a photo taken from my front yard of Francis Peak (see the two towers on top of the mountain) that stands 9,560’ (2,914 m). A couple days ago I rode from my home in Farmington, Utah an elevation of 4,380’ to Francis Peak in 1 hour and 20 minutes. The complete round trip took 1 hour 55 minutes a total climb of 5,180' - all in 25 miles. I have my controller programed for 9 PAS levels and I used levels 1 and 2 most of the way and occasionally 3 when needed. I have the 42T Italian chain ring installed to increase torque on steep climbs: http://www.alcedoitalia.it/shop/accessori-bbs/corona-42-denti-per-bafang-centrale-bbs01/
This red Cannondale M800 was converted for my wife. She can now keep up with me while I am on my EVO. After all – that is what the Bafang BBS02 is all about for us! It is the “great equalizer.” It allows the old and slower to ride with the young and fleet footed! As you can see I have removed the large off-road tires from this mountain bike and mounted a set of smooth road tires. She seems to like the stability of this frame.
Here are the battery packs that we put together for each bike.
Black Cannondale F5:
The Ibera triangle frame bag is medium in size and was purchased from Amazon: http://www.amazon.com/Ibera-Bicycle-Triangle-Frame-Bag/dp/B00H1KUCQY
This battery pack consists of four Zippy compact 5800mAh 6s 25c Lipo packs. With two connected in series and then in parallel with XT90 connectors and 10 gauge wire. The XT90 connectors proved to be perfect for this application. This pack supplies a total of 11.6Ah: http://www.hobbyking.com/hobbyking/store/__21383__ZIPPY_Compact_5800mAh_6S_25C_Lipo_Pack.html
Red Cannondale M800:
The Topeak Handlebar Bag that I also use on my bike when I go longer distances: http://www.topeak.com/products/bags/Compact_Handlebar_Bag
And the battery pack is made from six Turnigy 5000mAh 4s 20c Lipo hardcase packs. With three connected in series and then the two sets in parallel. As you can see I decided to use the stock Hobby King 4mm bullet connectors that made it easy to connect in series (but can be extremely dangerous if care is not taken when connected). This pack supplies 10Ah and costs half as much to build than the other pack: http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=18631
This is the bulk charger that I have been using: http://www.onlinecomponents.com/mean-well-hlg320h48a.html?p=43123430
I can fully charge each pack from 3.7v to 4.15v per cell in about 45 minutes and I use this Hobby King Medic to balance and check each pack: http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=41170 Occasionally I also balance charge each battery individually with this Hobby King RC charger: http://www.hobbyking.com/hobbyking/store/__7028__Turnigy_Accucel_6_50W_6A_Balancer_Charger_w_Accessories.html
I hope that this information will be helpful to you in your build...
