glv
This is my first ebike build. I'm a bit of a novice with bike mechanics and all these electrical details but I've turned my share of wrenches on cars over the years.
The donor bike is a Specialized Crossroads A1 with around 1500 miles on it. I've been commuting with it for years so I thought it only made sense to electrify it
Figuring I wouldn't get another shot at this I decided to get a bigger kit than I thought I needed. Reading around here it sounds like the real power junkies are all migrating toward geared drives so I ended up discounting the hub motors. I would love to have built an RC setup with one of Matt's custom built drives, but I was nervous to jump into my first build with something that seemed so complex and that's still in active development. That left the cyclone kits, which also had the bonus of being relatively cheap.
The kit was fairly easy to pick out, but the battery vexed me for a while. Luckily I ran across laufer's build thread where he noted he also planned to build a 1200w cyclone kit and found out that Ping was working on his next generation of packs capable of 3C continuous. Ping had some available via special request so I ordered one too.
The kit was pretty easy to put together. Cyclone supplies a longer 135mm asymmetrical BB spindle with the kit, but it's for an old-style cup-and-cone BB and my bike has a more modern cartridge-style BB. It was surprisingly hard to find retrofit cups; everyone has them on backorder ATM. I managed to scrounge one up at a local shop, but I got some funny looks asking for them.
I went a little overboard on electrical connectors. The folks at powerwerx.com must love me now. I got a bunch of 45A stuff, but I had trouble getting the 10AWG wires from the controller to seat correctly. I stepped up to the big bad 75A connectors for everything. Probably overkill, but what the heck.
It's not as neat and tidy as I'd like and having the battery mounted on the rear rack is not what I'd prefer, but overall I'm very happy with the final result, though there's plenty of room for improvement.
some pics of it in a bit of a patchwork state:
The battery lives in the trunk bag on top of the rear rack. I use the pannier for cargo. Note the fabulous "temporary" bungie mount for the controller.
The business portion
The other (drive) side. gotta love that tensioner
A close-up of the mount. The black screw in the top mount is threaded into the bottle cage boss. So far no twisting or shearing, but I will keep an eye on it. I've really cranked down on the nuts on the mount on and that black screw so hopefully it will all stay put.
The chain that broke on me the other day while shifting at full throttle. not recommended
You can see that the motor is not quite straight. I think it's just my fault for not quite mounting it correctly, I don't think it's moving on its own. It seems to work fine, but I may be affecting the efficiency a bit with the wonky chainline.
My next steps are to waterproof the controller and motor with some RTV and swap out the half-twist throttle for a xlyte thumb throttle. I'll probably wire up the CA current limiter at that point also so I can stop babysitting the amps and pay more attention to riding. I may try to move the controller to a nicer spot at some point and secure it more permanently.
My thanks to all the pioneers around here whose experiences made this much easier for me!
