12p3phPMDC
- Joined
- Mar 16, 2009
- Messages
- 462
That configuration gives the largest reduction right?
kentlim26 said:glv said:paco is sending me a new gearbox for the price of shipping ($30US).
US$30, it is acceptable, afforable for me too. I am pleased to hear that.
Miles said:9.33:1 [75t; 33t; 9t]
The ring gear is held by the aluminium case.
glv said:kentlim26 said:glv said:paco is sending me a new gearbox for the price of shipping ($30US).
$30 is ok, although free would be preferable. I hope you get more miles out yours than I did. I guess $0.08/mile compares favorably to driving a car, but swapping out drivetrain components every 3-4 weeks sounds pretty inconvenient (not to mention wasteful) to me. These components should last at very least 10 times as long IMHO, provided it really is rated for the output of the motor. A complete riding season would be nice.
lesdit said:The $30 is a special deal, I fear. The list price for the part is about $140 if I remember correctly.
They should at least sell the gear parts cheap, as a gesture of good faith.
Burtie said:Hi Glv,
Sorry to hear about your gears.
My 1200 Cyclone has been fine for about 400 miles so-far. When it was new I opened up the planetary box and found the grease inside to be very thick so that it would get pushed away into the corners and stay there not lubricating the moving parts.
My solution was to pour in some EP90 gear oil and mix the grease with it so it became less viscous. I thought would allow the lube to flow around the gears better.
Burtie said:My solution was to pour in some EP90 gear oil and mix the grease with it so it became less viscous. I thought would allow the lube to flow around the gears better.
GTA1 said:Burtie said:My solution was to pour in some EP90 gear oil and mix the grease with it so it became less viscous. I thought would allow the lube to flow around the gears better.
Sounds like you would be really well served by a all synthetic grease or gear oil.
alswiseowl said:Hi there,
its sad to see,such a good kit.made with crappy componets....
thanks for posting this,it has definatly put my purchasing of the cyclone kit to a hault..for the time being
+ the thought of having to open up the motor every 5 weeks,to replace or maintain,sounds like a p.i.t.a,let alone waiting for parts from overseas...
anyways keep us updated if you manage to source some good quality parts,like planets,ect
that fit & replace cyclone's ones.
take care
Miles said:Why don't you just get the Cyclone ones case-hardened? Presumably, the pinion already is...
