With the help of magudaman's work to produce the mounting pieces and my brother, the Mechanical Engineer, who helped with the CAD work and mounting the battery, I able to get this pretty nice mount on my FS mountain bike.
Battery Specs:
8 x 10s5Ah NanoTech 25-50C Lipo Stick (~1.5KWh of battery)
Wired in 2s4p (74V20Ah)
Total Weight of battery with wiring: 22-23lbs.
However since I only charge to 4.1V and discharge to only 3.6V, I get effectively around 16.5Ah or so. Last time I checked, I went 32 miles using 16.5Ah and the battery voltage was all balanced around 3.68V at the end of the ride. However keep in mind, I was using around 1.6KW of power only into the HS3548 Motor and averaging around 33-38mph depending on terrain and wind condition with a body weight of around 200lbs if you take into account the rack, and backpack I had on.
Increase that to around 2KW and my range effectively is reduced to around 25-28miles.
Here is the original bike review. You can see the evolution of the where I put the battery. : )
http://endless-sphere.com/forums/viewtopic.php?f=4&t=33528
Pictures are worth a thousand words:
Mount pieces. I didn't get a chance to take a picture of the pieces separately
Note it's 2 of the same pieces. I just reverse it on the other side. This kept manufacturing easy for magudaman.
This is the only place I can place the battery mount. Just as long as the screws are tight enough, friction will prevent these baby's from sliding down due to gravity.
here is the wood plates. I chose wood instead of metal because of 2 reasons:
1) Wood does not conduct. i.e. if there were loose wires, I won't have to worry about shorts especially when I am mounting Lipo on these.
2) Wood is easier to work with than metal. i.e. I can cut it to the shape I want with a saw. Metal I would need to use something else and probably a lot harder.
Bottom view. There is another piece of wood on the top and bottom to hold the top and bottom battery, but I did not get those shots.
I only have the shot of the complete battery mount. It is not terribly interesting to show the evolution of the battery. They are held on by velcro to each other and the wooden board.
Here is the wiring mess if viewed from the rider. The battery wire runs along the frame to back where I have the 18FET Lyen Controller.
How I charge. I use 2 icharger 1010B+ with PRC500 Power Supply. Each icharger will charge the 37V20Ah pack separately.
I have gotten comments on how the battery looks like a bomb strapped to the bike, but so far, it has not cause me too much trouble. I only keep the bike in a lab and at home anyways.
So far I love this bike. With the full suspension and the battery in the triangle section, this bike is very well balanced.
Overall Bike weight now is around 80-90lbs (35lbs from the bike, 15lbs from the HS3548, 10lbs from the rack and bag, 23lbs from the battery, 5lbs misc stuff).
The only thing left to do is to make a bag wrapping that will be water proof so I can take this baby in light rain.
Battery Specs:
