magudaman
Well it seems there is a small demand for a run of Norco A-line dropout replacements. If you don’t already know Oatnet had contracted me in December to make a set for his Aline and was amazing about getting the word out (lots of great photos too): http://www.endless-sphere.com/forums/viewtopic.php?f=6&t=34230&start=49
Since then I have got several emails from folks, so I am going to do a new design. I wanted to put up this thread to see what you all wanted from these.
What I want to keep:
- I would like to continue to use the 7000 series aluminum as the material. It has a PSI strength of almost 80,000 yet weighs almost ¼ of steel. Unless I use something like Domex most mild steels are similar in strength unless we harden. The original dropouts were 6061 which is about half as strong as the 7000 series.
- 135mm Axle spacing
- 1.5in Extension toward the rear for wheelie reduction
- Improve derailleur mount design
- Priced around $200 possibly lower
Requested changes:
- It seems most people would like a packman styled design with a tensioning bolt. I’ll have to do more research into the stresses at work here and see how well this will work as opposed to the fully enclosed design. With the milled in 135mm spacer you have almost a 3/4in of metal on each side of the axle. I am still not super fond of this idea since no matter what the enclosed design is insanely strong.
- Ensure axle is sitting on the flats and not the rounded section when installed
Here are some photos of the originals:
Requested changes:
