LI-ghtcycle
I have this DC to DC currently:
33 - 75Vdc in, and 12V, 12v, & 3.3Vdc out
http://cgi.ebay.com/DC-to-DC-Conver...786?pt=LH_DefaultDomain_0&hash=item56309513ea
I'm needing something along the same lines but I want it to be:
10- 30Vdc in (could be higher input voltage as long as the minimum is low enough) and 12v, 9V, 5V & 3Vdc out.
All of these outputs will be run from either 4S or 8S LiPo pack depending on how I configure it so from 14.8 - 29.6Vdc input, however I might be using closer to 12V at some point, so I'd like it to be able to accept at least something near 10-11Vdc and I'd really like it to be all in one unit.
A good friend of mine's father is an electronic engineer and is developing a device that will accept various voltage inputs and put out a steady output from a battery pack in various voltages automatically, however the prototype won't even be ready for use until I'm already on the road on around October 1st.
If there is a really compact, simple and efficient way to modify my current DC to DC converter, I might consider adding this:
12Vdc in to 9 & 5Vdc out
http://cgi.ebay.com/POWER-SUPPLY-12...959?pt=LH_DefaultDomain_0&hash=item563bff0fef
I have now found a DC to DC that will take 24Vdc In and out put 12, 12 & 5Vdc, this is the closest I have seen so far for my needs, and I am thinking maybe the best so far since it even comes with a heat sink attached!
