Ezee freewheel clutch stuck
TRRRR   10 mW
Post by TRRRR » Jun 12 2017 5:32am
Hello, I was riding my bike today and the motor was making noise while slowing down. After some investigation it turns out the freewheel is no longer working.
I disassembled the motor in my garage and took the clutch out - cant get it to freewheel. It seems the clutch is held together with rivets and cant be taken apart. Is there any way of repairing the clutches?
I have treated the motor pretty well, generally less than 700 W. Max 1000W. About 4500 kms over one year. Is this a bit early for a failure like this?
Ypedal   100 GW
Re: Ezee freewheel clutch stuck
Post by Ypedal » Jun 12 2017 7:29am
the 3 gears and the plates are one assembly, can be replaced with a new one.
This is unusual tho, they usually hold up for.. ever.
do the teeth look melted or distorted.. cracked? . .are they seized up and refusing to move ?
ES site status page:
d8veh   100 GW
Post by d8veh » Jun 12 2017 11:51am
I've managed to free stuck clutches in similar motors. You get a big lump-hammer and whack the wheel in the forward direction. After a few whacks, they free up if you're lucky. They were all fairly new though. I've seen other clutches stuck because of rust. You can't do anything with them.
TRRRR   10 mW
Post by TRRRR » Jun 12 2017 3:31pm
Thanks guys.
The gears and the internals of the motor still look new. No water damage or rust.
d8veh, I would be tempted to try the hammer method. Are you saying you whack the tyre of the bike wheel with the hammer to free it up?
Ypedal   100 GW
Post by Ypedal » Jun 12 2017 4:45pm
if you have it apart now, check for broken teeth that might be jaming up the works before you force it .. .. when all else fails, hammer.
TRRRR   10 mW
Post by TRRRR » Jun 12 2017 6:02pm
Thanks Ypedal, I have checked the teeth and they are fine.
I am going to try cutting a notch in the clutch disc then lodging a screw driver in the notch and hitting with a hammer. I will clamp the axle in a vice while doing this.
amberwolf   100 GW
Post by amberwolf » Jun 12 2017 9:51pm
If you weaken the clutch disc by removing material from it, there's a good chance it's just going to break in use at some point, and then it will freewheel in both directions.
If that happens, and there's enough space in the motor, you might be able to use a radiator hose clamp to put enough pressure across the break to at least get home, but I wouldn't make any bets on how long the fix will last. I didn't keep using mine (past getting home) after it broke and I fixed it with a hose clamp, so I don't know how long it would have held up.
https://endless-sphere.com/forums/viewt ... er#p550415
motomech   1 GW
1 GW
Post by motomech » Jun 13 2017 12:59am
Em3ev sells clutch assy's. They are the V2 version.
I think I have a couple new ones laying around somewhere.
Motomech
'03 Rocky Mountain Edge 2WD 260 Q100H frt and Ezee V1 rear 2 Elifebike 20A & 25A 9-FET controllers 12S/10Ah Multistar Lipo rear 4Ah Turnigy frt Luna Cyclops Extra lite Alex 24DM rims, Crazy Bobs run ghetto tubeless. 25 mph. Mean Well HLG-320H-54A
https://endless-sphere.com/forums/viewt ... =3&t=83430
'07 GT Idive 4 4.0, Q100C 201 14S LiPoly elifebike 9-FET 20A controller. 23 MPH.
https://endless-sphere.com/forums/viewt ... 4#p1378484
d8veh   100 GW
Post by d8veh » Jun 13 2017 2:51am
TRRRR wrote:Thanks guys.
Yes, whack the tyre.
TRRRR   10 mW
Post by TRRRR » Jun 13 2017 5:40am
OK, that sounds like the easy way to go, whacking the tyre without removing anything.
Are the Mac clutches interchangeable with the Ezee?
motomech   1 GW
1 GW
Post by motomech » Jun 13 2017 8:50am
Yes, same thing.
Motomech
teklektik   10 GW
Post by teklektik » Jun 13 2017 10:00am
You may just want to ride it for awhile - I have seized many clutches and they usually free up themselves - sometimes a few miles, sometimes a 100 miles, but sometimes never. Importantly, once a clutch seizes, it never holds as well again because the clutch surface on which the rollers or sprags slide can become deformed by the jam. This can make the rollers skip and just chatter instead of grabbing (like losing traction due to a bump in the road). So - you may do okay, but ordering up a replacement might not be a bad plan, even if you wait for a convenient time to install it.
Here's a post with some notes and installation vids - MAC/BMCs/eZees are structurally all about the same and have interchangeable gear clusters. Generally only the type and placement of shim washers varies between makes and models - so note that in particular when pulling things apart.
FWIW - the gears on these big gear motors almost never fail - try searching ES for failures in the last few years. Since the switch from the early nylon gears to the tougher composites a few years back, the weak link is the clutch - not the gears (smaller gear motor still use nylon so not the same situation). The clutches jam because of over-torquing which can come from overly aggressive controllers or simple road impact. Hitting a pot hole when under heavy power causes a brief but substantial torque spike and whammo - a jammed clutch as the rollers or sprags wedge tightly between the inner and outer clutch surfaces. If you see an evil road thingie coming, back off the throttle ASAP and the clutch won't take the hit.
thunderstorm80   1 kW
Post by thunderstorm80 » Jun 13 2017 4:25pm
If your controller allows regen, then forcing regen braking with a stuck clutch can almost certainly free it.
Maybe not immediately, but for sure after a few rides.
I once got a second hand stuck clutch due to rust, intended to be a permanent stuck clutch to research the efficiency of regen with ezee motor.
Even that one got free after few rides...
TRRRR   10 mW
Post by TRRRR » Jun 13 2017 10:15pm
Nice one, that regen idea sounds good to. I am running a grin tech phasrunner and CA3 so I am pretty sure I will be able to do the regen.
I haven't had time to try anything yet, maybe on the weekend
fechter   100 GW
Post by fechter » Jun 13 2017 10:59pm
You might like having regen more than having a clutch.
thunderstorm80   1 kW
Post by thunderstorm80 » Jun 14 2017 12:39am
fechter wrote:You might like having regen more than having a clutch.
No you will not.
After my experiment with regen on the ezee, it's just not worth it: The ezee wasn't meant to spin and deliver torque (positive or negative) all the time.
It overheats way too quickly if it doesn't have a resting period. Even just the component of the ezee constantly spinning without loading it creates significant heat via hysteresis and eddy losses because of it's small mass.
I purposely welded a clutch and drive with it for a couple of days in my hilly city. I really enjoyed the super powerful regen on one hand, but after few days, the gears melted from the gradual heat build-up: They were already soft enough from the heat build up and failed when I applied regen torque on a steep descent.
This is in addition to the NIGHTMARE of servicing the ezee motor: You have to unlace it in order to service it's internals. This means that whenever your clutch will fail,you will need almost a full day of disassembling, unlacing, and after servicing you will need to lace and true the wheel on a truing-stand. Still not convinced?
Just get a more powerful DD motor if you want powerful regen. It's reliable and won't break.
Read the thread I wrote about the experiment, which failed miserably:
https://endless-sphere.com/forums/viewt ... 30&t=83698
thunderstorm80   1 kW
Post by thunderstorm80 » Jun 14 2017 4:06am
No you will not.
I want to add one important note to what I wrote:
The ezee is a wonderful motor, if you use it according to how it was designed to be used.
It's small, yet still powerful, and it can provide impressive torque output, but only for a limited amount of time. It is an assisting motor by design, and this is why it has a freewheel clutch so it can rest and cool off.
I considered the option of permenantly locking it and making it de facto "DD" motor by using metal gears, but then the stator-coils are still trapped deep inside and cannot transfer their heat outside fast enough, require you to find a cooling solution which mechanically just isn't possible at all. (ATF fluid won't work)
And there is no temperature sensor inside that motor either.
So to conclude - just use it within the specs, and if you run it with Phaserunner and program it correctly (you can ask me how - I already have the experience), it can last a very long time. If the clutch seizes, just apply regen torque and it will be set free immediately, or after a very short time.
Ypedal   100 GW
Post by Ypedal » Jun 14 2017 6:26am
unless you have a different model, all the one's i've had on hand can be opened without unlacing.
http://ypedal.com/ezee.htm
thunderstorm80   1 kW
Post by thunderstorm80 » Jun 14 2017 12:32pm
Ypedal wrote:unless you have a different model, all the one's i've had on hand can be opened without unlacing.
The new motors that come with the modern cassette freehub instead of the standard freewheel-threads require unlacing in order to open the cover. The older ones do not.
