Kingfish
Greetings –
Many folks want to program their controllers via handheld devices as a matter of convenience. Without barging into other good threads on programming and their apps, why not focus on the specific challenges that at present inhibit this bridge of technology.
Simplistically, the goals should be scoped to explore and resolve the interface between common Chinese controllers using off-the-shelf serial communication technology:
USB Issues:
Bluetooth Issues:
Thoughts and ideas welcomed. I’d like to build a list of BT candidate boards and see if we can get one side of the equation to connect.
With potential, KF
- USB
- Bluetooth
USB Issues:
- Presently hardware exists to mate a USB cable between computer and controller (natch).
- Typical handheld devices (such as Android) do not allow for serial communication via USB without rebuilding the kernel. This is fairly easy to accomplish if you are adept at programming, otherwise not. In addition, this is an Inheritably problematic solution to deploy.
- Aside from the mobile O/S inhibitions, it seems easiest to fix in terms of hardware & cabling; nothing new to purchase.
Bluetooth Issues:
- Handheld programming application does not exist, though could be adapted with some effort.
- Requires a BT module, possibly a 5V -> 3.3V regulator to power it. BT boards appear to range from $7 to $15.
- Without a more sophisticated module, the hardwired commit-switch is easier to implement.
- Regardless, this is probably the best alternative for the DIY hobbyist if the mobile application existed.
With potential, KF
