marcexec
Guys, hope you can help.
Got my re-designed components in the bike recently and I am now stuck at trying to spin the wheel .
As above the KHB14301 draws ~240mA through a 40W bulb, the 2kΩ resistor is also in parallel. Voltage is ~92V.
No difference if peripherals or just the 24V in are connected. I always powered the logic circuit with a separate 4S battery.
I bought the controller used with the motor, supposedly working (any tips how I can test?): http://elmoto.net/showthread.php?t=4278
The controller shows me a 1,3 code - low voltage (thanks for the hint ).
Edit: servers me right using the fancy orange cables (like the OEMs) - had the poles swapped... Good lesson in using the precharge resistor and lightbulb before firing up the contactor, though
