superpef
- Joined
- Jul 28, 2013
- Messages
- 126
Hi guys,
I have recently been building my own electric longboard, so I thought I'd post it on here for people to see. This forum has been more than great help and I hope I can give something back, so please don't hesitate to ask, especially the "newbies" under you as I still consider myself one and wouldn't have been able to pull this off (even with Richard's and Bruno's kits) without the help of others..
So here's an overview of the components and parts I used:
- My beloved Rayne Killswitch (yeah it hurt to screw the battery case in there but I can remove it any time if I wanted)
- Alien Kit by Richard for Dual 50mm motors, Holey trucks
- Abec 11 Flywheels 76mm 75a
- 7s Battery case kit by Richard
- Twin 50mm Kit from Bruno (Twin 120A ESC with internal BEC and 2x 50mm motors à 2000W, 270kv
- Zippy Compact 7s 5800 maH 25C Lipo
- Imax B8+ balance charger 1-8s
- Graupner Power supply
- Modelcraft GT2 transmitter
- Arduino Nano V3.1
- Memorex wireless Wii nunchuck
- 10 awg cable to extend esc
- 5.5mm bullet connectors
- some heat shrink
- momentary switch for antispark cable
Now the main parts (motors, esc, truck mounts, battery) are exactly the same as on Richard's "commuter" board so you've seen them before and they have already been tested and verified to work great but here's how everything looks..
For now I am using the RC transmitter as it works perfectly. It only looks a little weird with that big pistol thingy in your hand, so I will either break down the thing and make it smaller or just wait for somebody else to do it 8). Toddy from the forum has developed a really nice code for his nunchuck/arduino setup that he was kind enough to share, so I will be playing with that in the future and see how it will handle. For now the RC transmitter is doing a great job. Again, thanks Todd for sharing and also explaining the stuff!!
The first test run was already an out of this word experience. I thought that if it would work have as well as I imagined, it would be awesome but it exceeded my expectations by far. Take off after one push is very smooth and controllable. The acceleration is just unbelievable and the board still handles really nicely, even with the motors mounted diagonally on front and rear truck.
I will be sure to post a video as soon as will be able to do some more runs.
Right now I am having trouble with my charger as it will recognize only 6 of the 7 cells of the battery.
I thought I killed my battery after ONE!! charge and discharge but it seems the low voltage cutoff by the esc worked just fine as my voltage monitor tells me the battery is fine. So it should be the charger.. No more testing until the charger replacement arrives..
My 2 cents on the recent discussion about Bruno being a distributor and not the manufacturer of the products: I am perfectly fine with it. For someone like me, support is a big factor and I think it's safe to say I probably couldn't have pulled this off without bugging the guy with LOADS of e-mails. He knows very well about his products and took time to answer each one. From support on my choice of components, to shipping everything I needed including stuff he bought for me on Hobbyking that wasn't available at my warehouse, to supporting me to get everything up and running, to bugfixing. Thanks for that!
Same goes for Richard, he also received loads of e-mails with questions. He is just as helpful and with these guys as suppliers, you definitely have a base for your DIY project.
Hope I could give you guys some insight. Keep your projects going!!
- Arduino Nano V3.1
- some heat shrink
