Fully installed and operational!
The whole setup was a bit fiddly and delayed due to various issues.
I had to fix the motor-mounting flexi-clamps to fit around my larger bike tube. It turns out these are
standard 06B (3/8) chain links used in industry. To add a chain link, grind off link end, then punch out link.
Either add a connector + 1/2 link + connector, or full link + connector.
In my search for chain links, I went to a few motor scooter places and ended up at an industrial products company ("G & R Industrial Products P/L" near my work) who had the links and the guy was very helpful and helped me complete the task.
This is the company if anyone is interested:
http://www.yellowpages.com.au/vic/colli ... sting.htmlTo complete the job I had to get 20mm heatshrink tubing from Dick Smith (can be sourced from many place) to have as-good-as-new flexi-clamps.
Review:The motor adds considerable power and gives an impressive push up the hill from behind. 200w feels like a lot. (It was freezing in the Melbourne cold last night, and even colder when you don't pedal - you feel cold and lazy.) You do notice the noise, it sounds like a hatchback in reverse, but I can live with that. One funny thing is when you are trying to roll the bike backwards (not sitting on it) as you do from time-to-time, it kind of drives the motor and is very stiff to move. The freewheel is only for going forwards.
I have a few outstanding issues:
- I can't get onto the largest (3rd) sprocket on the replaced Elation crank/sprocket set. I'll have to play around with the derailer.
- I lost access to the mounts on both frame tubes to put my drink bottle holders & pump. I have access to one mount point on the seat post tube. I suppose I can screw the holder into one mount point and get some kind of tape or adhesive to secure the rest of the holder. That is a bit annoying, but I suppose it is the sacrife you make to live in the future. Maybe you don't sweat if you don't pedal or you hold and sip on the ride?
I'll need to add a speedometer to see how fast I really go. I only weigh 50kg's. (Maybe the hub motors may have pushed me just as well.)
Happy riding
