byebyepetrol
Ditto here too. Performance is "reliable". I'm the only cyclist with electric muscles on my commute all the other poor buggers are bravely battling on. Masochists. Respect.
Pedestrians
I've found bells et al including a 140dB electronic beep horn are useless alarms for pedestrians. Especially when they're wearing headphones. I've fond the best warning cry is "heads-up!"
Phonetically optimal, it projects the loudest warning and is neither fawning or confrontational. Also easy to pronounce when you're busting your lungs.
New Pack 14.5AHr 36v
FYI Took a new 14.5AHr 36v battery and out of interest swapped it out with the 10AHr 4000km one. Result is an 2kmh extra across all speeds but still limited to 35kmh.
It only drops one bar out of the five? after my commute whereas the old pack drops 3.
I'll test its max distance on a long run this weekend.
Battery Mounts
Despite bumping the pack every time I carry the bike up the front steps to my house the bottle mount system hasn't failed. It flexes but that's all.
Front Tyre
I've dropped a few psi out of the front Schwalbe to reduce the harshness; down to 52psi from 60. Rolling resistance has barely changed and it's a lot nicer to ride. FYI I have no front suspension.
If I did it's likely I'd run a higher psi.
Pedestrians
Battery Mounts
Front Tyre
