ddk
- Joined
- Nov 4, 2011
- Messages
- 1,903
EDIT 6/03/2016
THE JUSTWIN COOL E-TRIKE FROM 2012 IS NO LONGER OFFERED SO DON"T READ THIS
I hope my review isn't what killed it's manufactured existence because this trike has (had) so many really good features I was just about to order another one when... IT"S BEEN REPLACED WITH A DIFFERENT "COOL E-TRIKE" -probably much easier and less expensive to manufacture as it uses a front wheel motor and a tiny lithium battery pack and only one seat. But I need the two-seater and would much prefer a rear motor so I won't be purchasing the "new" version.
edit 1/6/2016
]NO PROBLEMS WITH THE MOTOR after my personal rebuild back in '12.
I carefully reassembled the swag clutches and probably modified them a bit, but memory fails me as to what I actually did.
Beleze was ever so helpful during my initial purchase... I can't emphasize this enough. Justwin does make inprovements as they get reports back as my second controller was was a different version. Unfortunately because of connector issues I asked (and received) the earlier version (repaired)
Running the motor below 30V (7S Lithium Turnigy from HK) probably solved much of my issues with it. but I think the following info is still informative so:
edit 2-19-12
The Justwin's motor (edit- 2012) is subject to having the swag clutch self-destructif you ride the trike in reverse (like I have to do)
After this happened the first time I had to disassemble the trike to remove the motor, send said motor back for repair (to canada-shipping cost $100 of my dollars)
Upon replacing the motor it worked twice under the conditions I have to use it before the swag clutch blew out again.
(reversing the trike for 30 feet to leave my garage/workshop area)
My suggestion- DON"T BUY IT EXPECTING THE ELECTRIC PARTS TO NOT FAIL. I don't know if the trike is sold separately, which is really nicely built.
Ordered this to replace my recently squished custom tricycle.
cost: $2299
cost range: 2299-2899
Delivered from Belize Bicycles, it took about a week to get to me from Canada.
note- too large too heavy has to be shipped by truck (for me ~$200)
The truck driver was very nice. Called when he got to town and delivered it to my front yard.
The box was a little squished in the center but I assumed that wasn't a problem. The driver and I opened the box to verify no damage was done.
This trike is shipped fully assembled except the normal unmounted front wheel and handlebars.
The tires are all Maxis Hookworms
and no major struggle putting things together, which was good as rain was eminent.
The trike is well-equipped lighting-wise, having bright headlights, taillights and turn signals.
Even the speed-o is lit by a blue glow.
First impressions:
If this thing came with motorcycle rims it'd be a motorcycle. The tubes are BIG and the trike is HEAVY. Everything about it is heavy duty including the mudguard mounts. Impressive + I can just clear my leg over the tube.
The motor is HUGE, about 150-200mm thick, flange to flange.
Bad parts:
24V system- the controller has a fan on it
the horn is quieter than a bike bell- pretty useless.
Comes with 39Ah 12V sled batteries and my favorite brainless charging system. Charges though the controller and the charger is marked "not to used outside"
Also the trike is marked as to not ride in mist, fog, rain (maybe even sun?) -who knew?
Strangely enough the trike's steering is not any more stable than my weirdly-sprung custom builds.
more to come later, as it started raining.View attachment 6
edit 1/6/2016
edit 2-19-12
cost: $2299
First impressions:
Bad parts:
