Olivettibakebean
Hey whats up people? I started a thread on the no-hub forum but was soon convinced by one resident to go with a hub motor and that's just what happened.
The bike I picked is a 2004 Large frame Cannondale Jekyll 500. I got it for $500 and just needed to tighten a few bolts and return the calipers which whoever installed the new pads failed to do.
The bike has a 135mm drop out perfect for a 6 speed hub motor.
After placing my order for motor and cells I started on testing the lighting loom I wanted to make for the bike.
The 12v system on the bike comes from a golf cart voltage drop, I wanted to include:
1) Twin front spots
2) Rear light
3) Brake light
4) Rear turn signals
5) Horn
6) 12v cigarette socket
Each spot has a master switch so you can choose between them or have both on at once.
Lighting loom coming together while waiting for motor to arrive.
Reed switches have been mounted inside two old pen ends, drilled through and sprung for triggering the brake lights.
Two torque arms sold separately by Conhis.
Closed side of the cardboard mock up battery box.
Closed side of the cardboard mock up battery box with clamp attachments.
Open side of the cardboard mock up battery box.
1000w Conhis hub motor on a 26" rear wheel with a new cheap-ass tire.
Box taking shape from the 3mm birch plywood, I glued the box together and used duct tape to hold it together before fiberglass.
12v cigarette socket, I plan to use this to charge/run my phone/GPS from while riding.
Two stage key ignition, first stage is the 12v second is both.
Added some fake car air intakes to help the electrics breath inside the battery box.
1) Twin front spots
2) Rear light
3) Brake light
5) Horn
