tricky43
- Joined
- Jun 23, 2012
- Messages
- 16
Hi Everyone
My name is Rick, I'm a 44 year old auto electrician from Stockport in the UK
I've been riding mountain bikes since before they were called mountain bikes, I don't do it for the fitness (I'm not really that fit) I do it because I love getting out into the countryside and because for me there is no drug better than the adrenalin rush you get from barrelling down a hill at speed. I've always ridden light cross country hardtail bikes because you spend 90% of your ride getting up to the top of the hill and I don't like pushing.
I did have a couple of motorcross bikes when I was a teenager but no-one likes them if you try to ride them off road in the derbyshire peak district and you're likely to get arrested or shot by a farmer.
After riding the same bike since 1994 (an Orange Clockwork) I decided to retire it and get myself a new bike last summer. Super light with longer travel forks and disc brakes. 8) It wasn't until I'd got my new bike that I realised that the problem wasn't the bike it was the old bloke powering it doesn't quite have the power that he used to.
I have spent the last couple of months reading on the forum after coming across a video on youtube of a Stealth Bomber
[youtube]A4VRhIQPrtg[/youtube]
and thinking "I want one of those!"....... Then I found out how much they cost and that was the end of that.
A bit more searching and I came across a video by skeetab5780
[youtube]JLo659fiwDg[/youtube]
His build looked like it could be a little more like it could be in my budget.
Before I go on I think I ought to thank him for taking the time to catalogue all the steps of his build process, it gave me a great first insight of what was involved in building an eBike. Thanks Scott
Scott mentioned this forum in one of his videos and so a lot of evenings have been spent reading up on here and hatching my plan.
I wasn't going to start a thread until I'd actually got started with the build. At the moment I'm still getting the parts together but there's the rub, I can't figure out what bits are going to be best without some help.
Here's what I've got up to now.
Giant DH Team 18" frame
Its a 2003 so its got 135mm droputs. It had new linkages and a Rock Shox Vivid rear coil shock fitted in 2010, I got it real cheap, but its not all good news, the reason it came cheap is it has issues.
The top tube has been clanged by the triple clamp forks on both sides and there are small dents.
This is where I need my first bit of advice, I know this has weakened the frame and it might crack where the dents are but they're only small dents and I've never owned a frame anywhere near as beefy as this.
Unless one of you who has more experience with these things advises me otherwise I'm going to use it and keep my eyes peeled on eBay for another frame with a bent rear triangle so I can use the front triangle off that one.
My other thought is to wrap the headtube and first 3 inches of the top and down tubes with carbon fibre to strengthen it up a bit. Would that work do you think?
The only other issue is the rear derailleur hanger,
I'm not sure if it should be bent like this but I'm planning on using some of Kiwi's excellent rear dropout adaptors anyway so it doesen't matter.
I'm thinking of using these batteries
I can squeeze 6 of them in the front triangle if I put the controller on the bottom of the downtube,
With maybe another 2 or 4 on the front forks with one of Kiwi's Forklifts
I was thinking of starting with 4 (cos they cost a packet) for a 24s setup. they're rated at 25-50c would they have enough amps to power this or am I going to need 8 batteries (and a second mortgage)?
Its a Crystalyte x5306 and here's my controller a Lyen 4115 18 fet
My favorite bike on here is Keyne's awesome Giant DH team
and I'm hoping to build one just like it eventually with a 30s 2p 16ah battery pack and carbon fibre side panels.
To get going though I'm just going to use a frame bag for the batteries while I figure out all the wiring and see if it will get me uphill.
So here's the first thing of the many things I don't know and I need some advice with before I buy a front wheel.
The rear wheel is laced into a beefy 24" rim, I've got a pair of Fox 40's to put on the front of the bike so do I get a 26" wheel or a 24"?
If I get a 26" will it feel weird on the climbs like I'm going to fall off the back?
Will the controller mounted on the bottom of the downtube clear a 26" wheel when the suspension is fully compressed?
If I get a 24" wheel will it feel like a childs bike?
Thanks in advance...... Tricky
