paultrafalgar
Serial Hybrid Cycle with ICE Generator Onboard.
Inspired by the Selsyns and Amplidynes Thread
A serial chainless bike where the pedals run a generator is intrinsically less efficient than a direct chain driven one. However, if you have such a setup, you could, instead of using large batteries to store/complement the pedal-generated juice (which has a weight penalty), you could use a very small glo-plug model aircraft engine attached to a small tiny generator to boost charge a small auxiliary battery. Such small generators (e.g. http://www.m-dot.com/page8.html and http://www.dstarengineering.com/piston.html) could be used to augment the power of pedaling when coupled via a DC-DC converter. These small engines rev very fast, maybe 10000 rpm, so to direct drive a bike they have to be heavily geared down in 2 or 3 stages, each stage of which adds friction and hence inefficiency (see Matt Schumaker's project). However, by using the system described, a battery just big enough to act as a buffer between the generator and the motor would be all that was needed. Then, since we know from the title of this thread "11,000 watt-hours equal about a gallon of gasoline" it's better to carry gas, we can carry a litre or two of gas as our auxiliary power supply.
If anyone knows of a generator that is commercially available attached to a 1-10cc motor, let's hear about it.
What do you think?
What do you think?
