jmygann wrote:what is the gearing ? front # teeth ? rear # teeth ?
torker wrote:Awesome ! Save some room behind the seat for Lipo ! Either side of the frame= LipopodsMore pics please - looks fast..
def215 wrote:your work still amazes me lowracer. i also saw the video of the kokam pack that you were building in my youtube subscriptions. will that make its way on this project somehow?
D-Man wrote:I'm on dial-up. Can't see any video's. Pictures only.
thedarlington wrote:that thing is awesome, how did u get that insane chain ring did u custom make it?
AussieJester wrote:thedarlington wrote:that thing is awesome, how did u get that insane chain ring did u custom make it?
Pretty sure it is the one he made by hand from a saw blade?
KiM
thedarlington wrote:oh man i gotta try that! some chainrings are just retarded expensive, seen some even go for +$100 thats quite an original build u got there very ingenious solution
AussieJester wrote:Quick question LowRacer...how are you calculating the circumference of the saw blade so when
marking the teeth out you have the correct spacing all the way round? Is this a lil bit of trial and error?
Cut the circle mark the teeth see how it comes out if its not right cut a lil more off ?
Excellent job BTW, very impressive!
KiM
LOWRACER wrote:AussieJester wrote:Quick question LowRacer...how are you calculating the circumference of the saw blade so when
KiM
You don't need to calculate the circumference, if you calculate you lose!!!
You take a NEW CHAINRING and sign the every teeth....
You can see that in the video where I've created
the 99teeth chainring!
Of course my favorite material is chrome-vanadium, so I'd never to change that chainring!
AussieJester wrote:LOL thanks Miles, i have no idea what anything after 'Pitch diameter = Pitch' means though..
I'll stick with the softwar just need to type in the number of
teeth you want on your sprocket & it makes you a printable scale
pattern to stick to your metal 'disk' ... tiz my kind of easy![]()
KiM
Return to E-Vehicles General Discussion
Users browsing this forum: No registered users and 3 guests
