bandaro
daddz said:forgive my lack of knowledge, but that charger in the post above.
could i just buy several lipo packs to get my 24v 20 or 30amps. then just charge them a couple at a time? if that is so, could i also build up some sort of connection board so that i just plug each battery into its slot to build them up into 24v 20amp? then i could just wire my motor up to the board? would this be a safe reliable way to do it?
if that is possible how many batteries of what type would i need?
what i would really like is for some one with exp to jump up and say buy this do that and bingo. but i need to learn at the same time
sure can. i am going to have my batteries charged in 4 sets of 3s, making a 12s1p pack for the discharge. planning on charging via some balancing tabs i shall solder in, then have each set of batteries going to a board that i can discharge from. i am only charging as 4 sets of 3s as the rc chargers are generally limited to 50w, and the charger i have charges up to 5A each set, so 3s is the highest voltage that can take the full 5A charge ((3.2x3)x5=48w) so its fastest as 4 sets.
in regards for your board, its a nice neat way, but make sure that the set of batteries you are charging are isolated from the other batteries, otherwise the power will flow into the rest of the pack, effectively charging the whole pack at once, but not very well, possibly leading to smoke. this means you will need to solder plugs into the wires, so you can isolate a set. alternatively, you could charge all of your pack at once, with the cells rigged in parallel for the charge, and series/parallel for the discharge.
what i would recommend for you to do is get 4 packs of 6s 5000mah lipo's to make a 22.2v 20Ah total, then have a 6s charger, such as the one im getting here: http://www.hobbycity.com/hobbycity/store/uh_viewItem.asp?idProduct=11170 or a more powerful one if funds allow, and charge as 4 sets of 6s, then have the plugs from each battery on a board, and a second board that plugs over the first board that is rigged in parallel, going to the speed controller, so when that top board is unplugged, each 6s pack is isolated. by having a board holding the connectors its a single plug/unplug to isolate the packs, rather than 3 connectors to unplug. could make the top board a front cover of the battery box even, so its easy to get the cells out if need be.
it may be cheaper to buy the total 24 cells in a different configuration (ie 8x3s packs on special) but if you are not confident soldering directly on the cells, then go the 6s packs. alternatively, people are having success with power supplies set to the max pack voltage ( so for lipo: 4.2vx6=25.2v), and charging the pack as a single unit, letting the cells try to balance themselves out. i found this to be a bit more expensive for my configuration, and i understand the cells and circuitry so would prefer to manually monitor exactly what my cells are doing, but a meanwell supply or the like could be a great alternative for a charger, and charge faster than the linked charger.
