deVries
Since you're going to do long rides cross-country, I'd go with 15ah of LiPo as the main battery and just switch the Ping in as a spare or have it wired in with an isolator switch to cut-off the LiPo and another separate one to turn on the Ping. You should never parallel mixed chemistry -Ping w/LiPo for example.Crash Machine said:Sorry to break into this post with yet another question but I've read till my eyes are blurred the last couple of days. Is there a good configuration that will match the voltage of my 48v Ping pack(53 volts actually)? 14s is what I understand :? . Odd number? I would like to start by paralleling 10 Ah of Lipo to raise the C rating of the 15 Ah Ping battery. I have an X5 (40 amps) that is very hungry
Maybe the Ping could somehow charge/feed the LiPo once the voltage would drop in the main LiPo pack... but this would definitely require diodes to protect the Ping and a high charge C rating on the Lipo AND you would have to make sure the Ping would not over-charge the LiPo total pack voltage -Ping needs to be lower volts than top-off charge of LiPo.
I have not done any of the above, but I've read enough to know this should be possible. The Ping battery could then be placed perhaps in a better location with it feeding your LiPo.
Another method might be to use contactor-switches (sp?) to switch between each battery and use each battery separately. Search on DrBass' posts and contactor. Doctorbass: http://endless-sphere.com/forums/memberlist.php?mode=viewprofile&u=445
Search on booster packs and diodes too.
