Matze_Senpai
- Joined
- Apr 16, 2022
- Messages
- 134
so have you been able to drive the bike a little? is everything going good, are you satisfied with performance?edk01 is the name ?
Very good job I just bought such a motor and a USB cable for programming. Can you send me the update file?Tongsheng staff have a Facebook group. Here's the firmware update video. You can try searching for the firmware files there:
Regarding TSDZ8. We have published our review/test if anyone is interested:
TSDZ8 review and TSDZ2 OSF comparison (TSDZ8 vs TSDZ2 OSF)
Can you tell me where you bought this programing cable, or have you got maybe pinout jlink to Tsdz8??Very good job I just bought such a motor and a USB cable for programming. Can you send me the update file?
Please get in touch with Niki Baker on that Facebook group the video tutorial is coming from: Log into FacebookVery good job I just bought such a motor and a USB cable for programming. Can you send me the update file?
Chinese company means almost no warranty and practical no support. So ideal for diy....
Other vendors seem to sell the 48V/750W version for about €500, but theirs go for €285.
Or.. am I missing something here?
Who are these other vendors? on AliExpress, i find it for 349€. some seller called varstrom sell it for 360€Ok, so what's up with PSW-POWERS TSDZ8s?
Is this because of the cable problem mentioned on their page or what?
Since it looks like I need to cut the cable and connect my old TSDZ2-plug anyways, to fit it to my old battery:
It kinda seems like I can't go wrong with a €200+ discount. Especially since the alternative I'm considering as replacement for my busted TSDZ2 is a TSDZ2B for a mere €50 less..
Or.. am I missing something here? Firmware-Gremlins or whatnot?
Cheers,
/N
did you purchase on AliExpress? i would like to avoid bullet connectors, i hope they can deliver xt60 connectorMy TSDZ8 was delivered with bullet connectors, but I didn't buy at PSW. It is quite different to TSDZ2B. Bigger and heavier.
Be careful when buying from PSW. I ordered 17.5AH 48V Samsung battery and they delivered 36V 12.5Ah. Use credit card if you can.
£250 for TSDZ8 sounds like a very good price. I paid £330 few months ago, for legal version.
I think it's important to be able to lengthen and shorten cables as needed.
Soldering is not hard at all. I started doing it when I was 13 years old.
such nonsense. why should i spend 50$ on solder equipment that i use 1 time when i can buy battery connector adapter for 10$. at least i did that on tsdz2 and bbshd and havent had any problems yet. just because these Chinese are too cheap to use quality battery connector.. also your warranty is void when you solder a different connectorIf you aren't able to solder an XT60 yet, I wouldn't advise ebike kits. I think it's important to be able to lengthen and shorten cables as needed.
since there is no spider you have to either manufacture one or see if anything can fit out of the box . either way there will be horrible chainlineHas anybody found out how to get a dual front chain ring to the tdz8, something like 38/44, for instance?
Thanks, that does not sound too goodsince there is no spider you have to either manufacture one or see if anything can fit out of the box . either way there will be horrible chainline
if it's a custom frame maybe it's possible to move motor 35mm to the left and screw smaller sprocket to the existing original one keeping the chainline?just installed tsdz8 and need TSDZ8 130BCD adapter
130bcd should fit down to 38 tooth sprockets and possibly allow double sprockets. TSDZ8 is fitted on ice recumbent trike with a 48v 20ah 21700 pack.
Are there any other suppliers so I don't have to ship from Poland? Electric bikes accessories and parts | ebikestuff.eu
