Supertux1
Hello ESers!
I've got a few dumb questions. I'm kind of new to bike tech and ebiking in general, just bought my first donor bike! (It's a 29er hardtail from bikesdirect)
So I bought a bike for my build, but it's got a 10 speed SRAM X7 shifter, S7 rear derailleur and hydraulic brakes.
I'm thinking about an ebikes.ca or one of Cellman's geared MAC hubs on the rear, both of which take a 7-8 or 9 speed freewheel depending on how much I want to stretch the rear dropouts or not (it's a 6061 frame).
So the question is, can I get away with leaving the 10 speed shifter and on there with a less than 10 speed freewheel, or should I find an appropriate trigger shifter with the correct number for the hub freewheel? (eg SRAM X3 for the 7 speed). I'm thinking that things will be better indexed if I do, and if I don't there will be rough gear changes and disasters when switching into the lower 2-3 gears?
Second question, what do you do with hydraulic brakes and cut off switches for the motor that are mechanical in nature? Should I just replace one brake (say the rear one) with a mechanical pull or is there some kind of reed switch (eg BionX) that can be stuck to the hydraulic pull? (My brakes use DOT 5.1)
