1st Post, 2nd Conversion: Coleman youth ATV
mtbkrdave
Hi E-S! Looking forward to joining this community and to the projects to come…
My first conversion was electrifying an old Trek mountain bike with a 24-inch wheel kit, controller, and battery off eBay. Worked well as a commuter for a couple seasons, but the already-failing headset was getting too sketchy to ride.
Recently my older son (9) has gotten interested in ATVing. Wanting it to be electric, and for him to be able to work on it, I offered to build one with him. We visited a local Tractor Supply to take measurements from a Coleman AT125-UT ( https://www.colemanpowersportsusa.com/AT125-UT) youth ATV they had in stock. The manager stopped over and told us this particular one had never run; we ended up buying it for half price and free delivery. The final cost was less than I would’ve spent on aliexpress for the front/rear suspension, steering, wheels, and a pile of aluminum extrusion to build a frame.
After diagnosing and bypassing a bad ignition switch, the 120cc engine started on first-crank. So he’s having fun with it for now while I spec-out and price-out an electric drivetrain upgrade.
So far, I’m looking at various combinations of motor and controller, and the ATV-conversion threads on here have been super helpful!
  • The 120cc ICE engine is spec’d at 8Nm of torque, no power spec given
  • The vehice’s dry weight with ICE engine is 126kg. Kiddos are in the 18-25kg range now, but mom and I would like to take it for a spin now and then too.
  • Looking at various BLDC motors in the 2-5kW power range with torque ratings from 7-10Nm
  • Looking at VESC controllers and some of the other kits mentioned here: QS, Golden motor, Aliexpress unbranded…
  • Trying to figure out how to mate up with the existing driveline - it’s an integrated motor/gearbox, so I’m thinking a gear motor (like QS 3kW with integral gear reduction) would be easiest to direct-drive, or fall back to a similar-sized BLDC with an off-the-shelf jack shaft.
Suggestions on motor/controller choice more than welcome! Budget it not super-constrained, but I also don’t want to get way upside-down on value of electric drivetrain vs. the overall vehicle (noting, of course, that he and his little brother will eventually outgrow this, and I’ll be able to repurpose the bits for something else).
I’ll post some more before pics/details here soon, and once I (/we?) choose and source some parts, I’ll post tons of build detail… looking forward to diving in!
Cheers,
Dave
Update: We've done some benchmarking, and I think I'm narrowing down on a component set...
I mounted a GoPro to the quad, watching the dashboard. We did full-throttle-to-top-speed runs with my son (30kgs) and me (90kgs) riding. Knowing mass and [piecewise average] acceleration, I could back out the force, then extract torque given wheel radius. I was obv the worst-case:
I stepped through the video frame-by-frame and grabbed the timestamps each time the speedometer changed. While delta-V and delta-T got me piecewise acceleration, I suspect the speedo has a fixed >=0.5s update rate, resulting in the choppy output - we didn't really reach those MPH thresholds right when the speedo updated. I figured a polynomial curve fit would smooth that out reasonably.
We got a max force of about 1200N (276 lbf) for me, which seems reasonable to accelerate 215ish-kg of machine and rider. That translates to a max wheel torque of 281Nm. We worked back through the ratios: first wheel-size-to-sprocket-size, then driveshaft-sprocket-to-gearbox-sprocket, then gearbox-to-engine.
We got the last one by also noting the engine tach RPMs at each speedo update. That got us a gearbox ratio of 0.12 to 0.13 (neglecting lower revs when the centrifugal clutch was [presumably] still slipping). Working our way through, we got a max of 123Nm at the rear sprocket, 60Nm at the gearbox output, and 7.62Nm at the engine output. Lines up well with the motor's 7Nm spec.
I'm looking at using a QSMotor 138 3 phase internally-reduced BLDC, which gets us about 0.65Nm/Amp of torque:
https://www.aliexpress.com/item/3256801329527065.html
We're limited to 100A peak by our batteries (Headway 38120 x 20, 8 of which a coworker graciously donated), so the max motor torque is about 65Nm. That works well with the 60Nm max gearbox torque we extrapolated (lets say 65Nm assuming some loss to the chain, tire deformation, and slip), but what about speed range?
With a 1:1 gearing, the motor's 2955RPM redline would put us at.......158MPH!! That won't do. Switching the motor to an 11t sprocket and fitting the axle with a 50t sprocket, we'd end up with a top speed of 34MPH (likely slower with lower 20S voltage) and an insane wheel torque of 678Nm (only 2.5x the max we measured in testing). So we'll need a current limit on the motor to avoid flipping over backwards, but that's better than being underpowered, and lower peak discharge rates means longer battery pack cycle life.
I was glad to see my recollection of Physics 1 got us to a point where observed operation roughly correlated with the ICE engine's specs, gives me a bit more confidence selecting the electric motor (even if I'm erring toward over-powered - who knows, this powertrain might end up repurposed in a Vespa for my wife, or a motorcycle for me someday).
Cheers,
Dave
I have converted several ATVs and a SXS. My first conversion was a kids ATV which I wrote an article about it and might help you in your build. I started with a 2kW motor and worked but was close to overheating, even after I geared it right. I ended up with a QS 138 3kW which had plenty of power so I regulated it down in software. This worked great because I didn't have to worry about it overheating.
https://www.instructables.com/Kids-Polaris-ATV-EV-Conversion/
Here is a more recent video about the build https://youtu.be/CINFeNqkkP4
Cheers
One option to consider is whether to lean towards more volts, or more amps. Each has their benefits and drawbacks. Regardless of the drawbacks, I like 52V because that is the highest voltage that can power a common "48V" inverter to provide 120V AC in a power outage.
If you limit yourself to 52V, then you would get more power by raising the amps and adjusting the gearing to suit the new power profile. This makes the controller larger and more expensive, but it also makes the battery easier.
The motor will work fine with 52V-72V, and I have even seen these run at 100V
Thank you both for the input! Coincidentally, we had a 65°F February day today which has rekindled interest in the project among my young'ns... So we'll likely be starting to source components soon for a springtime dig-in!
Looking forward the checking out the video after work...
Cheers,
Dave
More on why to go with more volts. Disregard if you already know this, I don't mean to insult anybody's knowledge. Think of it this way.
Volts is HP (work/speed) which is directly proportional total weight the motor can push and the top work/speed it can reach.
Meanwhile Amps current is torque (ability to increase work/speed) which directly proportional to the quickness to get to that max work/speed.
72V and 80-120 Amps peak would be the goal for a kids quad that can carry an adult aka a big kid
for example:
high voltage and low current means it would have a high top speed or can carry a lot of weight but will take a long time to get to that max speed/work
low voltage and high current means it is slow and cannot carry much weight but will get to max speed/work quickly.
high voltage and high current is a Tesla Plaid :)
