marcoredit
1 W
Hi,
I have a Lion battery 36V 10s 8p (2200 mah - 17.6 Ah) with a 36V charger.
I connected the charger and it seems to work normally. It loaded all night, but the battery remained at 37,7V instead of going to 41V.
I checked the voltage of the battery and indicates 37.7V.
I checked the charger plug, and it's 42V.
I checked the fuse and it is ok.
When I connect the charger to the battery, if I check the cables +(positive) and - (negative) from the battery side, they gives 37.7V. Is it correct?
Should not give 42V, like the charger?
I can't understand what's wrong!
How can I check if the BMS is working?
Thank you
Mark.
Thank you
Mark.
