Jeremy Harris
cwah said:I have a direct plug from CA. So I suppose I don't have any shunt wire? I don't know how to recognize them.
The shunts are inside the controller. The direct plug in CA needs to be calibrated (using the procedure that Justin has outlined in the instructions I quoted earlier) to suit the value of the shunt in the controller.
If Lyen has told you that your controller as a 2 mohm shunt, then that is the value you program in to the Rshunt field in the CA.
