RonnieBrowen2106
I have decided to use fiberglass or aluminum stock to make side panels to keep the battery in place. I hope to use aluminum stock because it will be lighter. I will the drill two or three holes in the frame to bolt the two side panels onto the bike, that way they are removable. I will use bolts and wing nuts to make the teardown easy. I will use weather stripping that you typically put onto doors to help provide cushion between the frame and panels so there will be no rattling while driving. I hope to get the panels painted the same color as the bike, but I will use black or white if I have to. Maybe white because the shocks are that color.
