Russell
50amp max discharging current Newest 48v 11.6ah bottle battery pack, electric bike lithium battery, e-bike battery
http://www.aliexpress.com/item/Newest-48v-11-6ah-bottle-battery-pack-electric-bike-lithium-battery-e-bike-battery/1536761895.html
It sounded pretty good so in early July I ordered the battery plus a spare case (mostly to get a second mounting plate). On the 19th day after I placed the order I received notification of shipment. The tracking number provided however did not check out (btw, auto-cancellation of the order occurs at 20 days, so, hmmm...it makes me wonder...) I inquired and was told to wait a few days. I waited and checked, waited some more and checked again. The tracking number still came up invalid. After more correspondence I was told the order had been re-shipped. This time the tracking number checked out and the battery and case arrived in just a matter of a few days. The entire process however took nearly 5 weeks.
I installed the battery on my Electra Townie cruiser equipped with a Bafang BPM rear motor and a KU93 controller tweaked to 26Apeak output. After a brief top-off charge I took the bike out for a quick spin.
I was riding fast with very little pedaling during this initial shakedown run. Quick accelerations, 2 noteworthy hills and topping out at 28 mph takes its toll. The WU meter showed I used a whopping 29.5 Wh/mile for 3.06 miles, the most ever for me. Peak current was 25.84A and peak watts were 1267W. Voltage sag however is considerable at right about 1.8V per 10A. To put this in perspective the "High C Rate" 36V/15Ah battery I purchased a few months back from BMSBattery sags roughly one-third as much.
Per the Vendor the battery is equipped with 3C Samsung 29E cells. I did not open the battery to verify since doing so would break the seal and void the warranty. The specs in the ad vary, in one section they show this:
Item specifics
is_customized:Yes
Voltage:48v
Capacity:10 - 20Ah
Type:Lithium Battery
battery power:48v 11.6 ah
cycling times:1200 times
battery style:bottle battery
continous discharging current:25amp
max discharging current:40amp
net weight:5kgs
material for cell:LiNiCoMn
charger:2amp bottle battery charger
cell:lithium ion 18650 3.7v 3000mA
and in another section they list these specs:
48V 11.6AH 18650 Imported cells battery pack spec electric bike battery . (Cells are more like 2750mah so 11Ah total)
• 18650 cells 2900mAH imported , 52 cells with bms (vendor says they're Samsung 29E)
• 800 times cycling ,one year warranty
• cell weight : 48g
• discharge cut-off voltage : 2.5v for one cell
• operating temperature discharge : -20°c to 60 °c
• 48v 11.6ah discharging current continous : 35amp (the cells are 3C max so this really should be maximum discharge)
• 48v 11.6ah max discharging current : 50amp (I questioned the vendor about this and they stuck to it but c'mon, no way!)
• charging current max : 5amp
Note: The battery is protected by a replaceable 30A blade type fuse.
To date I have done 4 rides with the battery using a maximum of 8.523 Ah with a resting voltage after that ride of 45.86V. So far it has performed without a problem. One of the rides were with the battery on my Jeep Comanche equipped with an EBK geared motor and 22A KU93 (shown below).
It achieved a top speed of 28.5 mph. I removed it however since I prefer using the BMSBattery 36V/15Ah battery in the topeak rear bag with this bike as it affords better range with a still decent 24 mph top speed and better stealth.
I also tried the battery on my flatbar road E-bike with a 201 rpm Q100 and 14A KU63. Top speed was roughly 22.5 mph. The biggest inconvenience with using this type of battery is the need to find another place to mount water bottle cages. In this instance I mounted 2 cages to the handlebars. Again however I removed the battery after the test run since the second mounting plate is ultimately destined for a new build which will likely be a 48V/18A/500W Bafang BBS02.
Quoted spec's aside this is not a high power battery. It has performed fine so far however personally I would not recommend it be used with a controller over 25Ap. I would probably also advise a different vendor. I see BMSBattery now carries this type of downtube battery and then there's also EM3ev.com which gives much more reliable information.
-R
Item specifics
is_customized:Yes
Voltage:48v
Capacity:10 - 20Ah
net weight:5kgs
• cell weight : 48g
-R
