999zip999
100 TW
My A123 20ah cells can only deliver 18ah. But for 840 cycles. Oh so far. And still 18ah. No bms very hard regen. May be that the regen is awaking them up. With a charge pulse. Just a guess.
999zip999 said:My A123 20ah cells can only deliver 18ah. But for 840 cycles. Oh so far. And still 18ah. No bms very hard regen. May be that the regen is awaking them up. With a charge pulse. Just a guess.
bthunderstorm80 said:I am still surprised why people use gun powder as their power source.... (LiPo's)
madin88 said:LiIon has about two times or more watt hours per weight and volume. this means if you have 1000 charge cycles on a LiFe battery, you would have only 500 on a LiIon battery.
I once thought about using A123 M1B for one high power bike because they can be charged extremely quick and are ery safe, but if you compare all Pros and Cons, LiIon makes much more sense for EV so i went with such.
madin88 said:Some years ago the A123 M1A/M1B cells had been hyped for RC model usage because of theire robustness and the possibility for charging / discharging them at extreme high levels. I personally have used them too, but replaced them later by LiPos because of the much higher energy and power density.
If sombody is looking for robustness, safeness and extremely high cycle life, A123 is a winner for sure.
Lets compare the M1B (76g) with a Samsung 30Q (48g) at 10A discharge:
regarding http://www.dampfakkus.de, the 30Q performs following: 2,93 Ah, 9,84Wh (down to 2,5V) -> 205Wh / kg
As it will degrade quick when using it 4,2-2,5V, i usually program my controller between 4,15-3,3V which results in about 15% less usable Wh, but will give 3 times higher cylce life (many times proven).
ok, than it has 175Wh / kg
The M1B performs following from my calcuation when looking at discharge graphs: 7,65Wh at 10A when discharged down to 2V
https://images-na.ssl-images-amazon.com/images/I/711o+u+UACL._SL1500_.jpg
so it has 101Wh / kg which is only 57% of the 30Q
now think further:
you could use 75% more 18650 cells in terms of weight (and probably volume too) so the stress on the battery will be reduced further (like 6A discharge current per cell vs the previous 10A, less stress during regen), and in the end you have many many times the cycle life of initial specification :wink:
M1B is no more attractive than if all considered, and after working with more than 3000 18650's (mostly from Samsung) i can give following adive:
If the cells come from the SAME CHARGE, if the pack is BUILT PROPERLY (mostly i terms of equal current flow through every single cell), and if you don't always squeeze out all the capacity, it will stay balanced very very well and will last for years.
check out this diagram about degradiation of tesla batteries:
less than 10% in 8 years is something i could live with.
https://electrek.co/2016/11/01/tesla-battery-degradation/
liveforphysics said:To my knowledge, not a single vehicle OEM in the world is using A123 products today for an EV traction battery (I think a couple Chinese cars use them for start-stop ICE batteries today).
A123 was unquestionably an industry leader when the M1 cell first emerged 11-12 years ago.
While holding that tech/industry leadership position, they decided rather than evolve the product to stay relevant, to instead join a handful of big industries in getting fleeced by lawyers selling them "IP" kool-aid and lawsuits (the function of IP).
Anything you choose to cling to and "protect" in the exponential age is your own ensured obsolescence. However much you involve lawyers in your product or company is how much you want to get fleeced in exchange for non-contributing harms creation for yourself and others.
Today A123's LFP cathode tech is abandon-ware and someone there with vision partnered with solid-energy which uses a modern cathode interfacing a solid electrolyte, which is at least a useful RnD path forward, and I wish them the best.
It is nothing special, they just don't charge and discharge the cells to 100% and take care about the temperature, so they get many many times the cycle and calendar life of initial specificationsthunderstorm80 said:Sorry for the very late reply...
I would like to know where you can buy such cells as the Tesla ones.
I am sorry, but I would like someone to show me, A REAL, and PURCHASABLE battery cell, which has similar properties to the Tesla spoken above. I didn't find one. It's either high specific energy (220Wh/Kg or so) by paying for much less cycle life, or lower density of 170Wh/Kg but still getting 500 cycles if you use your battery to it's max.
Any other chemistry is not economical at ALL in the long run. The glory of that high-energy density is a very temporary one, with a sad end (mostly to your bank account).
thunderstorm80 said:What happened to this company and why everybody recommends LG/Samsung cells that although have an initial higher specific energy at the beginning of their service, they lose the advantage to the A123 after 1.5-2 years and keep declining while the A123 stays intact. (The A123 with their LiFePo4+nano technology have a negligible aging effect)
Even the famous 30Q Samsung cells will lose significant portion of the capacity after 250 cycles if you fully discharge them and at their max discharge rate.
Your calculations regarding the specific energy are wrong - First, the prismatic cells of A123 have 133Wh/Kg, but we can assume 120Wh/Kg on practice. It's the 26650 cells that sit around 100Wh/Kg. Second, if you lower your maximum charging voltage to increase the life cycle so you are at around 175Wh/Kg, then you are not having double the density of A123 - even if we talk about the 26650 cells. With the prismatic cells, which can be brutality discharged, the difference is 175/120 - much less than a factor of 2.
And last, after 1-2years you would have the same density as A123 pack, due to aging and life-cycle capacity loss, but your clock doesn't stop there. You will keep getting lower and lower capacity while the A123 chemistry stays almost completely fresh...
